    Volume script
    2.0k
      This is my current Windows batch script to set the volume on my laptop using nircmd.
      I can say, "Alexa, set volume on laptop 90" to set the volume to 90 percent, or Alexa, turn off volume on laptop" to mute it.
      @echo off
      if "%1"=="" goto :usage
      if "%1"=="on" goto :on
      if "%1"=="off" goto :off
      goto percent
      :on
      echo Unmuting volume
      nircmd mutesysvolume 0
      goto done
      :off
      echo Muting volume
      nircmd mutesysvolume 1
      goto done
      :percent
      set percent=%1%
      echo Setting volume to %percent% percent
      set /a "num=65535*(percent %% 101)/100"
      nircmd setsysvolume %num%
      goto done
      :usage
      echo %0 on, off, or 1-100
      echo For example, these commands will mute the volume:
      echo %0 off
      echo %0 0
      :done
      echo Done.
      Giuseppe SbirziolaG 1 Reply Last reply Reply Quote 0
      • N
        Nate Hales
        Actually love this one!
        MeximistasM 1 Reply Last reply Reply Quote 0
        • MeximistasM
          Meximistas @Nate Hales
          @Nate-Hales in spanish?
            Russ @Meximistas
            @Meximistas, I think Alexa would accept one of these:
            establecer volumen 90
            subir el volumen a 90
            You'd make the Voice field volumen instead of volume.
            • Giuseppe SbirziolaG
              Giuseppe Sbirziola @Russ
