Email says command didn't run, but it did.
I am running the agent on macOS 26.2 - Whenever a command is triggered via Home Assistant, i get an email that the command failed to run, however it actually did.
Is there a way to supress the emails, or is there some logging on the agent to indicate why it thinks the command did not execute?
@David-Coulson, I'll look into it.
One thing you can check in the meantime make sure this checkbox is unchecked in your profile:
Can you show me one of the emails? I wonder if it's reminding you to subscribe because you're running more than 1 command per minute. I'll add an option to disable those emails too.
Also, did you enable "Home Assistant Offline Configuration"?
EDIT: I added this checkbox that you can uncheck to stop the subscription reminder emails:
@David-Coulson, I fixed it. Now you won't get these "TRIGGERcmd - Your command didn't run" emails if the trigger was from Home Assistant.
Thanks again for reporting the problem.
