    New MCP server in web UI
    1 Posts 1 Posters 625 Views 1 Watching
      Now you don't have to install the TRIGGERcmd MCP server in Claude or VSCode if you just want to try it out. You can use it right in your browser, if you're subscribed.
      Also, as of agent version 1.0.50, a new mcp tool will be added for any command that has an MCP Tool Description:
      Your description should explain to the AI LLM what the command does and how to use the parameters. For example:
      "This is a color LED light bulb that you can turn on or off. You can also change the color. The parameters are on, off, or a color like red, blue, green etc."
