    TRIGGERcmd with Smarthings using Schema Cloud Connector
    smartthings
    1.1k
    • TheDreamer68T
      TheDreamer68
      Even though the site says the cut over date from Cloud Connected Device Integrations in Developer Workspace to Schema Cloud Connector in Developer Center isn't until August 5th, 2025. When I go to try to create a new Cloud Connected Device Integration, it says the new Schema Cloud Connector is available... choosing to stick with the old way doesn't advance me from that menu. So, guess its the only way going forward at this point.
      So, I'm lost what to do after step 14. Don't know how to get to 15, etc. At least I found Developer Mode in the iOS app....held the About Smartthings for about 5 seconds (the background changes back slight before I reach 5, and there's a small shift in the page...took me a couple tries scrolling up and down to realize it was at the bottom. But, haven't deployed anything yet, so nothing to see yet.
      TheDreamer
      RussR O 2 Replies Last reply Reply Quote 1
        Russ @TheDreamer68
        @TheDreamer68, give me some time to look into this. I'll get back to you soon. So far it seems SmartThings broke this integration recently. I'm finding their new system does not synchronize with the "My Testing Devices" list in the SmartThings app.
        I created a new Schema App and found it doesn't show up in the SmartThings app under "My Testing Devices."
        I also migrated one of my existing Schema Apps using the smartthings schema:update command, but it doesn't work. I also renamed it and the new name doesn't show up in the SmartThings app under "My Testing Devices."
        • Cristian DindinelliC
          Cristian Dindinelli @Russ
          @Russ so, in this moment the integration with Smartthings is a little bit messy?
            Russ @Cristian Dindinelli
            @Cristian-Dindinelli, yes so far I haven't been able to get it working after the recent change Samsung made.
            • O
              orsonbrice189 @TheDreamer68
              @TheDreamer68!!
              It sounds like you're navigating the transition from the old Cloud Connected Device Integration to the new Schema Cloud Connector, which can be a bit tricky. Since the changeover is already happening, it’s best to follow the new path for creating integrations. If you’re stuck at step 14, it might be helpful to review any specific documentation or guides provided by SmartThings, especially around the Schema Cloud Connector setup.
