    The sleep comand doesnr suspend the pc its hibernating
    6 Posts 3 Posters 1.9k Views 1 Watching
    • E Offline
      Ego95
      rundll32.exe powrprof.dll,SetSuspendState 0,1,0 any one knows wich comand can i use
        Russ @Ego95
        @Ego95, please try this nircmd command.
        nircmd standby
        https://nircmd.nirsoft.net/standby.html
        • E Offline
          Ego95 @Russ
          @Russ Doesnt work dont know why
            Russ @Ego95
            @Ego95 does it work at the command line if you run it manually?
            And did you install nircmd?
            • Diego Ulises Pérez RuizD Offline
              @Russ Hi, it only works if I manually activate it. But Alexa doesn't run it. You know why?
                Russ @Diego Ulises Pérez Ruiz
                @Diego-Ulises-Pérez-Ruiz, maybe you need to specify the full path to nircmd.exe in your command, like c:\tools\nircmd.exe ...
                Also, by manually, I assume you mean when you run it manually from the command line it works. What if you run it manually via TRIGGERcmd using the green Trigger button on the website, or from the green Play arrow in the GUI Editor ? We should make sure those work before attempting Alexa.
