    How to create a trigger
    • G
      gigaboy
      I'm wanting to use this to restart mysqld using ifttt on a server that does NOT have a GUI.
      All the docs I'm reviewing state to launch a GUI to create the command.
      Nothing like that in the TriggerCMD interface.
      Take a look at this AI generated result from Google Search:
      https://www.google.com/search?q=how+to+trigger+a+mysql+restart+on+ubuntu+using+ifttt&oq=how+to+trigger+a+mysql+restart+on+ubuntu+using+ifttt&gs_lcrp=EgZjaHJvbWUyBggAEEUYOTIGCAEQLhhA0gEJMjIwMzdqMGoxqAIAsAIA&sourceid=chrome&ie=UTF-8
        Russ @gigaboy
        @gigaboy, thanks for sharing that link. I'm loving the fact that Google gave you that answer - to use TRIGGERcmd via IFTTT.
        If your server doesn't have a GUI, you'll have to edit your ~/.TRIGGERcmdData/commands.json file manually, using a text editor like vi (aka vim) or pico, nano etc.
        On Linux, your default ~/.TRIGGERcmdData/commands.json file includes the first 5 commands. I added the 6th command you could use to restart mysql, like Google says.
          {"trigger":"Gnome Editor","command":"gedit","ground":"foreground","voice":"notepad","allowParams": "false"},
          {"trigger":"Calculator","command":"gnome-calculator","ground":"foreground","voice":"calculator","allowParams": "false"},
            "trigger": "Restart MySQL",
            "command": "sudo systemctl restart mysql",
            "offCommand": "",
            "ground": "background",
            "voice": "restart",
            "voiceReply": "",
        Notice I made "ground" = "background" because without a GUI, you probably installed the background agent (with installdaemon.sh) which runs the TRIGGERcmd agent in background mode as service.
        • G
          gigaboy @Russ
          Perfect! Thanks for your help!
