    Ubuntu 22 - Installation throws permission denied, no prompt for token
    9 Posts 2 Posters 3.3k Views 1 Watching
    • G Offline
      gigaboy
      This is a server, no GUI
      Logged in as a user.
      Installation is normal until the end:
      N: Download is performed unsandboxed as root as file '/home/gigaboy/triggercmdagent_1.0.1_amd64.deb' couldn't be accessed by user '_apt'. - pkgAcquire::Run (13: Permission denied)
      gigaboy@twilight2:~$
      I'm user gigaboy, not "apt"
      After this, there is no prompt for inserting the token.
      Tried this twice, uninstalled, reinstalled, same problem.
      If I run the installdaemon, I get this:
      gigaboy@twilight2:~$ sudo sh /usr/lib/triggercmdagent/resources/app/src/installdaemon.sh
      Daemon install: true
           Active: active (running) since Mon 2025-04-07 06:23:23 CDT; 445ms ago
         Main PID: 316544 (node)
            Tasks: 7 (limit: 4562)
           Memory: 23.7M
              CPU: 283ms
                   └─316544 node /usr/lib/triggercmdagent/resources/app/src/daemon.js --run /root/.TRIGGE>
      Apr 07 06:23:23 twilight2 systemd[1]: Started TRIGGERcmd Agent.
      Thanks for your help.
        Russ @gigaboy
        @gigaboy, I see your background agent is running with /root/.TRIGGERcmdData as its data directory, so please switch to root with sudo su - then run this command to enter your token:
        Then restart the agent with this command:
        systemctl restart triggercmdagent
        Then, you can put your commands in your /root/.TRIGGERcmdData/commands.json file with ground=background.
        I'll have more time to run through the ubuntu instructions later today, but if you see this before then, please try the above and let me know how it goes.
        EDIT: I tried it on Ubuntu 24 and I got that same error but it worked fine.
        • G Offline
          gigaboy @Russ
          @Russ Thanks for your update.
          Did as you prescribed.
          Threw an error "can't find module 'fs/promises'"
          restarted triggercmdagent
          but then when I check status states that service has failed.
          Here's the complete sequence:
          root@twilight2:~# node /usr/lib/triggercmdagent/resources/app/src/agent.js --console
          Daemon install: false
          Logging in with saved token.
          Checking if the null computer exists.
          This computer was deleted from your account.  Login to recreate it.
          prompt: token:  [hidden]
          Token saved for next time.
          internal/modules/cjs/loader.js:818
            throw err;
          Error: Cannot find module 'fs/promises'
          Require stack:
          - /usr/lib/triggercmdagent/resources/app/node_modules/chokidar/index.js
          - /usr/lib/triggercmdagent/resources/app/src/agent.js
              at Function.Module._resolveFilename (internal/modules/cjs/loader.js:815:15)
              at Function.Module._load (internal/modules/cjs/loader.js:667:27)
              at Module.require (internal/modules/cjs/loader.js:887:19)
              at require (internal/modules/cjs/helpers.js:85:18)
              at Object.<anonymous> (/usr/lib/triggercmdagent/resources/app/node_modules/chokidar/index.js:7:20)
              at Module._compile (internal/modules/cjs/loader.js:999:30)
              at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
              at Module.load (internal/modules/cjs/loader.js:863:32)
              at Function.Module._load (internal/modules/cjs/loader.js:708:14)
              at Module.require (internal/modules/cjs/loader.js:887:19) {
            code: 'MODULE_NOT_FOUND',
            requireStack: [
              '/usr/lib/triggercmdagent/resources/app/node_modules/chokidar/index.js',
              '/usr/lib/triggercmdagent/resources/app/src/agent.js'
          root@twilight2:~# systemctl restart triggercmdagent
          root@twilight2:~# systemctl status triggercmdagent
          × triggercmdagent.service - TRIGGERcmd Agent
               Active: failed (Result: exit-code) since Tue 2025-04-08 11:33:38 CDT; 17s ago
              Process: 604516 ExecStart=/usr/bin/env node /usr/lib/triggercmdagent/resources/app/src/daemon.j>
             Main PID: 604516 (code=exited, status=1/FAILURE)
                  CPU: 455ms
          Apr 08 11:33:38 twilight2 systemd[1]: triggercmdagent.service: Scheduled restart job, restart count>
          Apr 08 11:33:38 twilight2 systemd[1]: Stopped TRIGGERcmd Agent.
          Apr 08 11:33:38 twilight2 systemd[1]: triggercmdagent.service: Start request repeated too quickly.
          Apr 08 11:33:38 twilight2 systemd[1]: triggercmdagent.service: Failed with result 'exit-code'.
          Apr 08 11:33:38 twilight2 systemd[1]: Failed to start TRIGGERcmd Agent.
          lines 1-12/12 (END)
            Russ @gigaboy
            @gigaboy, looking into this now.
            EDIT: @gigaboy , I re-read your post. I see you're trying to use the agent on a server without X-Windows. I just tried that and I see I need to fix some things so give me some time to produce a new version.
            • G Offline
              gigaboy @Russ
              Great, thank you!
                Russ @gigaboy
                @gigaboy, you're welcome. I found a separate problem I'd like to solve in a new version, but since then I also found the specific problem you ran into.
                I found the latest version of the triggercmd agent doesn't work with node version 12, and node version 12 gets installed by default on ubuntu 22 when you install nodejs. It worked fine for me on my ubuntu 24 because it installed node version 18 when I ran apt install nodejs.
                On your ubuntu 22 you could use nvm (node version manager) to install node version 16 (or greater) like this:
                curl -o- https://raw.githubusercontent.com/nvm-sh/nvm/v0.39.3/install.sh | bash
                export NVM_DIR="$HOME/.nvm"
                [ -s "$NVM_DIR/nvm.sh" ] && \. "$NVM_DIR/nvm.sh"  # This loads nvm
                [ -s "$NVM_DIR/bash_completion" ] && \. "$NVM_DIR/bash_completion"  # This loads nvm bash_completion
                nvm install 16
                In case it got bad data from a previous failed run, you should delete your ~/.TRIGGERcmdData folder like this:
                rm -rf ~/.TRIGGERcmdData
                Then run the agent again like this:
                I like the flexibility of nvm, but here's another option for installing nodejs version 16:
                apt remove nodejs -y
                curl -fsSL https://deb.nodesource.com/setup_16.x | sudo -E bash -
                apt install -y nodejs
                Thank you for reporting your issue btw, and thank you for your patience.
                • G Offline
                  gigaboy @Russ
                  Well I did as you suggesteed:
                  1. node 16 is no longer supported, so I installed node 20 LTS
                  The server was seen in the TriggerCMD web console.\
                  However, when I ran systemctl status triggercmdagent, shows failure and the server is disconnected from the console.
                  Notice too the error thrown before I issued the status command.
                  Here's the code:
                  root@twilight2:~# rm -rf ~/.TRIGGERcmdData
                  Local Home Assistant Configuration file not found at /root/.TRIGGERcmdData/home_assistant_config.json
                  Local Home Assistant listener is disabled.
                  Computer ID [hidden] saved for next time.
                  Write backup completed.
                           Connected at: Thu Apr 10 2025 15:01:01 GMT-0500 (Central Daylight Time)
                  Initiated command removals
                  Computer name for Local Home Assistant listener: null
                  Error fetching computer name: TypeError [ERR_INVALID_ARG_TYPE]: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received null
                      at Object.writeFile (node:fs:2311:5)
                      at /usr/lib/triggercmdagent/resources/app/src/ha.js:120:10
                      at process.processTicksAndRejections (node:internal/process/task_queues:95:5) {
                    code: 'ERR_INVALID_ARG_TYPE'
                  { message: 'Subscribed to 67f8237d3395ce0013c3aef0!' }
                  Initiated command adds
                  Added Calculator
                  Added Gnome Editor
                  ^C
                       Active: failed (Result: exit-code) since Tue 2025-04-08 11:33:38 CDT; 2 days ago
                          CPU: 455ms
                  root@twilight2:~#
                    Russ @gigaboy
                    @gigaboy the errors you see here:
                    Those errors are actually what I want to fix in the next version of the agent. The errors are related to the new Home Assistant integration. It errors like that on first run because it can't fetch the computer name. If you don't use Home Assistant you can ignore it, and if you do, just restart the agent.
                    Anyway, to solve your problem, please try this:
                    Then check the status again with this:
                    That will restart it and if it can find node 20, it should work. It just has to be above node 12, so 16 could work too.
                    Let me know how goes please. Also, what method did you use the install nodejs? nvm or apt?
                    • G Offline
                      gigaboy @Russ
                      the restart and status check worked!
                      I used apt for the removal and node update.
                      Thanks again for your help!
