    Comandos
    • E
      Ego95
      No logro hacer funcionar ningun comando en triggercmd y cuando le doy a mostrar ejemplos la pestalla se queda en blanco. que puedo hacer.
        Russ @Ego95
        @Ego95, can you send a screenshot of the blank examples screen?
        Also, do you see your computer and its commands in your account at triggercmd.com? Do you see anything in the Runs list for the commands after you click the Trigger button?
        E 3 Replies Last reply Reply Quote 0
        • E
          Ego95 @Russ
          @Russ Thanks for the reply The problem disappeared after updating the program in Windows. But I still don't understand how to turn on my PC using wakeonlan with Alexa from triggercmd. And I have a doubt, use the command to suspend the PC but I see that it is like hibernating instead of suspending. When I suspend the PC and click on the mouse, the lock screen usually appears, but when I use the command and use the mouse, even the motherboard logo appears.
          • E
            Ego95 @Russ
            @Russ its possible to use a comand like this wakeonlan /s /t 30 start firefox http://www.youtube.com that power on pc and wait 30sec to launch firefox in that specific website
            • E
              Ego95 @Russ
              @Russ the shutdown comand doesnt work
