    Open/Close .exe +Lights on Google Home routines
    4 Posts 2 Posters 1.6k Views 1 Watching
    • john lagos ramirezJ Offline
      john lagos ramirez
      Hello!
      I have a routine integrated with TriggerCMD but it only works from my phone (google home) and not from my pc.
      What i made successfully is create a Routine on the Google Script editor that whenever i start my command/trigger, it opens steam.exe, this triggers my led strip on or off, depending on the parameter sent (both starters on the same code)
      # Visit g.co/home/script-editor-docs for full documentation.
      metadata:
        name: test steam + light rgb escritorio
        description: Scripted automation
      automations:
        - starters:
            - type: device.state.OnOff
              state: on
              is: true
              device: Iniciar Steam - Oficina
          condition:
            state: on
            is: false
            device: Led escritorio - Oficina
          actions:
            - type: device.command.OnOff
              on: true
              devices: Led escritorio - Oficina
          # SECOND STARTER #
        - starters:
              state: on
              is: false
          actions:
              on: false
      this is on the .bat file:
      taskkill /F /IM Steam.exe
      I added on the triggercmd Command and off command on and off text to the end, i dont know if that sends the parameter but at least is working (maybe if i delete that it works anyway)
      But what is not working is the automation triggering when i open the shortcut from my pc or the .exe, is it possible to make it work like my phone? i want to open Steam from my desktop and this triggers my routine, therefore turning on my strip lights and also when i stop/kill/close the .exe it turns off my light, i cant make it work like that
      thanks!
        Russ @john lagos ramirez
        @john-lagos-ramirez, if you open and close steam from your PC via TRIGGERcmd it should trigger your Google Home routines that turn your lights on/off.
        Please try this:
        1. Download the tcmd tool
        2. Rename it to tcmd.exe
        3. Move it in your c:\windows folder so it's in your PATH.
        4. Right-click your desktop and create 2 shortcuts that run these two commands:
          tcmd -t "Open/close steam"-c "PC John"-p on
          tcmd -t "Open/close steam"-c "PC John"-p off
        For example:
        I created similar shortcuts to open/close calculator via TRIGGERcmd:
        You can customize the shortcut icon if you want.
        john lagos ramirezJ 1 Reply Last reply Reply Quote 1
          john lagos ramirez @Russ
          Hi @Russ
          I followed your instructions and it is working excellent now 👌
          Thank you so much!
            @john-lagos-ramirez, awesome.
