    Agent in macOS Sonoma Task Bar
    4 Posts 2 Posters 1.3k Views 1 Watching
    • A Offline
      abaratz
      Re: Mac app issues
      I just installed the agent on another MacAir M3 running Sonoma. As in the referenced post, the agent is showing up in the task bar (actually both the task bar and the menu bar). I am experiencing exactly the same problems as in the referenced post. I looked at the info.plist and LSUIElement is not there. I tried adding it, but after restarting the system, the agent application would not start. By the way, when I looked at the info.plist on my MacBook Pro M2 running Sonoma, the LSUIElement setting was there. In fact, the info.plist file was quite different on the MacBook Pro - many fewer entires. I'm wondering if I am somehow picking up an older version of the software?
        Russ @abaratz
        @abaratz, the agent is built with Electron and I upgraded Electron a while ago. That's probably when the Info.plist file changed.
        I'm looking into this now. I'll get back to you soon. I understand the goals are:
        1. Get rid of the icon in the menu bar
        2. Make sure it starts up when you log into your Mac.
        EDIT: It's done - the Info.plist file has LSUIElement = true now. Please download the latest Mac agent version. It no longer gives you the extra icon in your bar at the bottom of your screen. I also verified it starts when I login, although that was working for me before this update.
        • A Offline
          abaratz @Russ
          @Russ Hi Russ, I apologize for the delay in responding. I was traveling. Yes - That fixed it. Thank you for the quick fix.
            Russ @abaratz
            @abaratz, awesome. Thanks for confirming.
