    How do I mute Realtek speakers on my Windows computer?
    6 Posts 3 Posters 1.6k Views 1 Watching
    • D Offline
      D0llyy
      What is the command to mute Realtek speakers on my Windows computer?
      RussR D 2 Replies Last reply Reply Quote 0
        Russ @D0llyy
        @D0llyy, if you want to mute your speakers on a Windows box, you could use nircmd like this:
        nircmd mutesysvolume 1
        https://nircmd.nirsoft.net/mutesysvolume.html
        • D Offline
          D0llyy @D0llyy
          @D0llyy I tried it and it didn't work. Here is a screenshot.
          • D Offline
            D0llyy @Russ
            @Russ I copied the nircmdc.exe, nircmd.exe, and NirCmd.chm to the Local Disk (C:) Then I lunched the Command Prompt when I typed the >nircmd in the command this message pops:
            and then when I tested the command using >nircmd changesyssysvolume -15000 it didn't work and that message kept showing and I keep clicking okay
              Russ @D0llyy
              @D0llyy, I see the problem. Your command is wrong. It should be this:
              nircmd changesysvolume -15000
              Your command has a double sys in changesyssysvolume.
              • A Offline
                Ancar
                Go into Sound settings, find your Realtek device, and disable it there if you don’t want it to play anything at all.
