    triggercmdagent and tcmd are not recognizing changes to commands.json
    • D
      DarkGreen92
      I've got the tcmd cli tool installed, and I tried installing triggercmdagent (headless, both foreground app and daemon), and either way, it doesn't seem to recognize when I edit the /root/.TRIGGERcmdData/commands.json file. When I run "tcmd --list", it only shows the "Gnome Editor" command that comes by default, and none of the ones I added. I even removed the Gnome Editor command and that one still shows up.
      Restarting triggercmdagent (app or daemon) as well as the machine itself seems to have no effect.
        Russ @DarkGreen92
        @DarkGreen92, I'm glad you asked instead of giving up. I don't know what you OS is, but I think it's Linux and not Raspberri Pi.
        I think the commands.json file that your background agent daemon is using is the one in your user's home folder at /home/(your user)/.TRIGGERcmdData/commands.json, not root's home folder.
        Also, the background agent will only process (add/remove/run) your background commands in the commands.json file, not the foreground commands like Gnome Editor.
        When you use tcmd --list, you're listing the commands in your account, not the local commands in your commands.json file. I think it's only listing Gnome Editor because that command got added to your account when you ran the foreground agent once, and entered your token to log it in.
        You could also try running this command to show you which .TRIGGERcmdData folder the daemon is using:
        There's my output from my Raspberry Pi. It's using the one in /root because that's what the Raspberry Pi agent uses by default. I think you'll see your non-rpi Linux agent using /home/(your user)/.TRIGGERcmdData.
        pi@garagepi:~ $ systemctl status triggercmdagent
           Active: active (running) since Thu 2023-07-13 03:17:03 UTC; 10 months 5 days ago
         Main PID: 262 (node)
                   └─262 node /usr/share/triggercmdagent/app/src/daemon.js --run /root/.TRIGGERcmdData
        • D
          DarkGreen92 @Russ
          @Russ Sorry I didn't specify. I'm running Debian headless inside Proxmox. I think the problem might actually be that the service is repeatedly crashing after start up. When I run doas systemctl status triggercmdagent I get this:
          × triggercmdagent.service - TRIGGERcmd Agent
               Loaded: loaded (/etc/systemd/system/triggercmdagent.service; enabled; preset: enabled)
               Active: failed (Result: start-limit-hit) since Sat 2024-05-18 17:05:02 EDT; 7min ago
             Duration: 389ms
              Process: 2757 ExecStart=/usr/bin/env node /usr/share/triggercmdagent/app/src/daemon.js --run /root/.TRIGGERcmdData (code=exited, status=0/SUCCESS)
             Main PID: 2757 (code=exited, status=0/SUCCESS)
                  CPU: 385ms
          May 18 17:05:02 core-services systemd[1]: triggercmdagent.service: Deactivated successfully.
          May 18 17:05:02 core-services systemd[1]: triggercmdagent.service: Scheduled restart job, restart counter is at 6.
          May 18 17:05:02 core-services systemd[1]: Stopped triggercmdagent.service - TRIGGERcmd Agent.
          May 18 17:05:02 core-services systemd[1]: triggercmdagent.service: Start request repeated too quickly.
          May 18 17:05:02 core-services systemd[1]: triggercmdagent.service: Failed with result 'start-limit-hit'.
          May 18 17:05:02 core-services systemd[1]: Failed to start triggercmdagent.service - TRIGGERcmd Agent.
          Running
          doas systemctl reset-failed triggercmdagent
          doas systemctl start triggercmdagent
          gives me what I think is the expected output at first:
               Active: active (running) since Sat 2024-05-18 17:17:22 EDT; 113ms ago
             Main PID: 2860 (node)
                Tasks: 7 (limit: 2307)
               Memory: 15.7M
                  CPU: 102ms
                       └─2860 node /usr/share/triggercmdagent/app/src/daemon.js --run /root/.TRIGGERcmdData
          But then checking status again right after gives me this again:
               Active: failed (Result: start-limit-hit) since Sat 2024-05-18 17:17:23 EDT; 2s ago
             Duration: 406ms
              Process: 2860 ExecStart=/usr/bin/env node /usr/share/triggercmdagent/app/src/daemon.js --run /root/.TRIGGERcmdData (code=exited, status=0/SUCCESS)
             Main PID: 2860 (code=exited, status=0/SUCCESS)
                  CPU: 388ms
          May 18 17:17:22 core-services systemd[1]: triggercmdagent.service: Deactivated successfully.
          May 18 17:17:23 core-services systemd[1]: triggercmdagent.service: Scheduled restart job, restart counter is at 5.
          May 18 17:17:23 core-services systemd[1]: Stopped triggercmdagent.service - TRIGGERcmd Agent.
          May 18 17:17:23 core-services systemd[1]: triggercmdagent.service: Start request repeated too quickly.
          May 18 17:17:23 core-services systemd[1]: triggercmdagent.service: Failed with result 'start-limit-hit'.
          May 18 17:17:23 core-services systemd[1]: Failed to start triggercmdagent.service - TRIGGERcmd Agent.
          Do you have any advice on how to fix the crashes?
            Russ @DarkGreen92
            @DarkGreen92, I think you could see the error if you run the command the daemon is running:
            It looks like it's running as root, so you should be root too when. You run that command.
            I see it's trying to find the agent config in /root/. TRIGGERcmdData so please show me the contents of that.
            It might just need the token to login. You can give it that by creating a token.tkn in that folder, or run node agent.js --console and it should prompt you for it if it's missing.
            • D
              DarkGreen92 @Russ
              @Russ That seems to have done it! I think my mistake was mostly running it as a standard user. When I switched to root and ran node agent.js --console, it did prompt me to input the token. After that I was able to restart the service and now when I check status, it always shows as active.
              Thanks for your help.
                Russ @DarkGreen92
                @DarkGreen92, great. You're welcome. Thank you for your patience.
