variable return not being reproduced in alexa
Hi, I'm having difficulty sending the command return to Alexa, could you help where the error is?
I'm running on a Raspberry Pi 3 and an Echo Dot 5 generation
I installed both the triggercmd smarthome skill and execute command
@santana2196, it looks like you've got everything working except that you're trying to use the Smart Home skill that doesn't support the Voice Reply feature.
Only the "conversational" Alexa skills support it.
Hi, thanks for the quick response @Russ , I'm still a noob, I would like an easy example of how to configure using TRIGGERcmd
,TC or TRIGGER command ? -
@santana2196, ok, first you need to enable one of the conversational skills, like the original TRIGGERcmd Alexa skill.
Then say, "Alexa, ask TRIGGERcmd to run execute."
Notice you don't say, "Alexa, turn on execute" like you would with the TRIGGERcmd Smart Home skill.
I used "execute" because I see in your screenshot that "execute" is the name of your trigger.
I just noticed that the TRIGGERcmd skill is not available for Brazil,
Anyway, thanks for the support.
@santana2196, oh that's true. Sorry. Please use one of the other conversational skills.
I think I'd recommend the TC skill in this case.
Also, please check out the portuguese documentation page about the conversational actions.
