    Ubuntu 14.04.1 LTS
    4 Posts 2 Posters 1.8k Views 1 Watching
    • drmoddingD Offline
      drmodding
      I'm getting the following error
      I assume that it is related to the version I am using from node, could you tell me the versions with which your script works?
      I am using a Kodibunto distribution that is basically an Ubuntu 14.04.1 LTS
        Russ @drmodding
        @drmodding, I'll have to get back to you after I try Kodibuntu myself. So far I like your theory that the node version is too old. I don't know exactly which versions of node work, but I do know old versions don't work.
        EDIT: I installed Kodibuntu and ran into this because I'm using VirtualBox. So I'll try Ubuntu 14.04 next.
        alt text
        EDIT 2: This method worked for me on Ubuntu 14.
        sudo su -
        wget https://s3.amazonaws.com/triggercmdagents/triggercmdagent_1.0.1_amd64.deb
        dpkg -i ./triggercmdagent_1.0.1_amd64.deb
        apt-get install -f
        exit
        triggercmdagent
          drmodding
          Thanks, I will try the procedure that you send me.
            Russ @drmodding
            @drmodding, thank you. Please let me know if it works or not.
