    Turn Monitor Off doesnt work with Alexa
    1.1k
    • R
      ricardomat
      Re: Turn Computer Monitors Off
      When I click run the command in current commands the monitor does turn off, but when I tell Alexa to turn it off, she says "ok" but doesn't turn off the monitor. On Windows.
      RussR ? 2 Replies Last reply Reply Quote 0
        Russ @ricardomat
        @ricardomat does it work if you click the green Trigger button on the website?
          A Former User @ricardomat
          @ricardomat Which command do you use pls? Looking for a working one. thnx
            Russ @A Former User
            @David-0, this command works for me on my Windows 11 box:
            nircmd monitor off
            These are the relevant docs for that nircmd function:
            https://nircmd.nirsoft.net/monitor.html
            You could also consider this command:
            MultiMonitorTool.exe /TurnOff 2
            You'll need to make sure nircmd.exe or MultiMonitorTool.exe is in a folder referenced in your PATH environment variable. I just talked about that with @h6477801471 here:
            https://www.triggercmd.com/forum/topic/2725/monitor-control-command-issue/2
