    Respaldo?
    Example Commands
    • Oscar MroO
      Oscar Mro
      Como crear un respaldo de mis comandos?
      RussR A 2 Replies Last reply Reply Quote 0
        Russ @Oscar Mro
        @Oscar-Mro, good question.
        I translated it as, "how do I backup my commands?"
        Your commands are in your commands.json file, so you could copy that to dropbox or google drive so they're backed up to the cloud.
        The commands.json file is in the .TRIGGERcmdData subfolder of your user's home folder. So in my case, on my Windows computer it's here:
        C:\Users\russe\.TRIGGERcmdData\commands.json
        On my Raspberry Pi it's here:
        /root/.TRIGGERcmdData/commands.json
        • A
          aaaaa12345 @Oscar Mro
          @Oscar-Mro
          Under Windows: open TCMD's "Text Command Editor" with a right-click on its notification bar icon. It is displaying the path/location of the "command.json" file that contains your TCMD configuration. Save a copy of that file. Or cut&paste the editor's content into a text file of the same name.
          Google translation:
          En Windows: abra el "Editor de comandos de texto" de TCMD haciendo clic con el botón derecho en el icono de la barra de notificaciones. Muestra la ruta/ubicación del archivo "command.json" que contiene su configuración de TCMD. Guarde una copia de ese archivo. O corta y pega el contenido del editor en un archivo de texto con el mismo nombre.
          HTH
