    Echo show cards
    7 Posts 2 Posters 1.3k Views
    • L Offline
      legtod2
      On echo show and google display screens can we display text and buttons?
      • L Offline
        legtod2
        For example when I say :
        Echo open triggercmd.
        Echo show screen displays:
        Say something like run calculator on officepc
        Launched
        Can I control this display to display something else
          Russ @legtod2
          @legtod2, not yet but I could build something. Please explain what you'd like to do using the screen. I've thought about giving the ability to use panels from the screen.
          • L Offline
            legtod2 @Russ
            @russ
            I would like for the echo show screen to remind the user to give my own examples of trigger cmds
              Russ @legtod2
              @legtod2, I think I understand. So when you say, "Alexa, ask TRIGGERcmd to run calculator" it will run calculator, and also on the screen it will show other things you could say to run your other commands?
              So it might show this text on the screen:
              Other commands:
              Alexa, ask TRIGGERcmd to run ...
              notepad
              netflix
              calculator on laptop
              • L Offline
                legtod2 @Russ
                @russ Correct. Simply a trigger cmd with the ability to display text or a media picture or object to the echo show. It could also be helpful like
                for run calculator
                for run close calculator or more helpful reminders
                I am creating an interface to fruitbox jukebox
                So when I want to increase volume or pause or skip songs I can add text display to echo show screen.
                  Russ @legtod2
                  @legtod2, I remember your fruitbox jukebox project. It's a cool idea. I might end up dedicating one of my own Pi's to that use-case.
                  You're apparently using the TRIGGERcmd or TRIGGER command skill. Both of those skills allow you to specify text that Alexa will say and display after the command runs.
                  You can set that text for the command in the GUI editor:
                  In my commands.json it looks like this:
                  "voiceReply": "Also try, \"Alexa, next song.\"",
                  BTW, for "Alexa, next song" to work, you'd need to create an Alexa Routine to run the next song command when you say that.
