    Alexa -->TriggerCmd-->Pi-->Fruitbox Jukebox integration
    5 Posts 2 Posters 3.2k Views
    • L Offline
      legtod2
      I have a Raspberry Pi running Fruitbox Jukebox application. I modified the application to provide Text to Speech to announce songs before they play. Now I would like to integrate Amazon Alexa so that I can power on/off the pi (that's simple), and have my own integration to the fruitbox jukebox application. I want it to do commands like volume Up/Down, Play, Next, Pause, Stop, Play selection A1, Play random/Shuffle, Play playlist 80's music.
      There are existing skills out there like plex, mymedia, that do this stuff but it stream the music via the alexa device. I want the application to behave like a fancy remote control via voice and the music playing from the pi not alexa.
      I probably could also use the Linux Lircd remote control samples to but I am not using that to control the app.
      Any sample scripts and curl like urls for volume control, play buttons, etc that could help me on my journey ?
        Russ @legtod2
        @legtod2, I like the idea. Are you going to use hdmi for audio output or the headphone jack?
        My initial google research found this. It has commands for changing volume etc.
        http://raspberrypi-aa.github.io/session3/audio.html
        • L Offline
          legtod2 @Russ
          @russ I have the pi inside a 1945 Radio Cabinet. The Audio out is via the headphone jack to an amplifier. The pi is connected to a 7" touchscreen display so the user can navigate the menu interface.
          I will set up a short youtube to provide details of the project.
          https://www.youtube.com/watch?v=AF1oHlUs0z8
          Here is the family of raspberry pi/arduino projects. Jukebox at the end
          https://youtu.be/elCitgHJhkA
            Russ @legtod2
            @legtod2, if you can control it with a keyboard, you might be able to use this "keyboard" python module to make commands that simulate keyboard strokes.
            https://github.com/boppreh/keyboard
            • L Offline
              legtod2 @Russ
              @russ Very cool suggestion. Send the equivalent to pressing a local keyboard keypress.
