    Could I request another example of using IFTTT to call triggercmd?
    2.3k
      A Former User
      Here is an example that was posted regarding this issue.
      I have a Google Home Mini and only 1 computer called "PVR".
      I have successfully created multiple commands that work great through the mini. The 2 problems with this setup are the amount of yappin' that takes place every time I request an action AND the fact that only my voice can activate the commands. Google tells me that IFTTT does not require voice matching, so anybody can execute the commands and I believe I have complete control over the Mini's yappin'.
      As a result, I want to transform all of my commands to be mini->IFTTT->triggercmd rather than mini->triggercmd.
      Here are my specifics:
      token=1234 (example)
      Command Name=Pause DVD
      Voice Command=DVD Pause
      Russ, could you recreate the example cited above using my specifics?
      Thanx.
        Russ @A Former User
        @rbmcgee, your IFTTT Webhook should make a web request with method POST to:
        https://www.triggercmd.com/api/IFTTT?trigger=Pause DVD&computer=PVR
        You can use a space or a %20 between the word Pause and DVD.
        It should look like this:
        IFTTT
          A Former User
          Thanks Russ. Will give it a go this weekend, but I think I've got it.
