Progressive Web App with Panel support at https://app.triggercmd.com
Just go to https://app.triggercmd.com to access it. Then you can save it to your iOS, Android, or PC and it will behave like an installed app.
This is what the app looks like on Windows, installed via Chrome:
If you use Edge, the option to install looks like this:
This is what it looks like in Chrome on Android:
@Russ Thanks very much - this is great!
@russ
I love that this shows the number of times one has actually has triggered devices. -
@russ using this in my edge browser either on the PC or phone I noticed there are only trigger buttons no On/Off so any smart home things that use arguments like ON OFF won't run.
Things that have arguments set to false do work.On my Android phone though using the samsung browser everything is fine.
@tuicemen , the PWA has two modes:
- Display Computers
- Panels
You toggle between them using this slider:
They roughly map to the "Your Computers" and "Your Panels" pages on the triggercmd.com site.
Computers mode currently only gives a TRIGGER button for each command.
Panels mode allows you to configure a set of buttons for each command that will send various parameter values.
This shows the configuration for the Volume command - notice the Parameters field has Up,Down,Mute so my Music panel has those 3 buttons for the Volume command.
I think the PWA is probably most useful for panel users at this point.
If you have ideas for how to improve it, let me know.If you're seeing different things on different devices even though you're in the same page in the app, you might just need to refresh the page.
@russ, Ok I see what I'm doing Wrong!
For some reason my samsung browser loaded with display panels and edge loaded with display computers.
All is good!
