    Automatic charging of notebook battery
    • Paulo VascoP
      Paulo Vasco
      I would like help to create an automation when the notebook battery is 95% charged, it turns off the smart socket sensor. And when it reaches 10% charge, it turns on the smart plug sensor.
      Has anyone done something like that?
        Russ @Paulo Vasco
        @paulo-vasco, I downloaded this BatteryInfoView tool and ran it on my laptop with this command:
        d:\tools\BatteryInfoView.exe /scomma d:\tools\battery.csv
        This is the output I got:
        C:\Users\Russ>type d:\tools\battery.csv
        Description,Value
        Battery Name,8850
        Manufacture Name, Hewlett-Packard
        Serial Number,Li4402A
        Manufacture Date,
        Power State,Discharging
        Current Capacity (in %),89.0%
        Current Capacity Value,"76,730 mWh"
        Full Charged Capacity,"86,213 mWh"
        Designed Capacity,"98,235 mWh"
        Battery Health,87.8%
        Voltage,"11,630 millivolts "
        Charge/Discharge Rate ,"-37,551 milliwatts "
        Chemistry ,Lithium Ion
        Low Battery Capacity (1),"6,038 mWh"
        Low Battery Capacity (2),"3,074 mWh"
        Critical Bias,
        Number of charge/discharge cycles,0
        Battery Temperature,
        Remaining battery time for the current activity (Estimated),
        Full battery time for the current activity (Estimated),
        Remaining time for charging the battery (Estimated),
        Total  time for charging the battery (Estimated),
        You could write a script that loops once per minute and reads the Current Capacity (in 😵 value from that output.
        The script could run one command that turns on your smart switch when the battery gets low, and another command that turns the smart switch back off when the battery is full.
        Those two commands could be tcmd commands like this:
        d:\tools\tcmd.exe -t calculator -c russhp
        Instead of calculator you could make it something like switchon and switchoff, then use this method to run an Alexa routine that flips your switch on and off when you run those commands.
