    address incomplete at trigger
    • Ilm HomI
      Ilm Hom
      Hi!
      i try to chrome open this "http://192.168.0.xxx:6095/controller?action=keyevent&keycode=power" and worked for 3 times. After that i changed only the ip address because the fist one was a test.
      The trigger is now:
      "command": "start http://192.168.0.203:6095/controller?action=keyeventkey&code=power",
      "offCommand": "",
      "ground": "foreground",
      "voice": "",
      "voiceReply": "",
      "allowParams": "false"
      but doesnt work anymore, after the "&" trigger not consider anymore in address, i saw it is "&" because if i changed the place in address, trigger only goes until that.
      I look in another issues in forum and saw a answer by Russ tell for put "c:\program file..." etc but doesnt work for me.
      Someone could help me? Thank you in advance!!!
        Russ @Ilm Hom
        @ilm-hom, assuming you're using Chrome as your browser, you could do something like this:
        This is the text version, notice the escapted quotes \" inside the json quotes.
        "command": "start chrome "http://192.168.0.203:6095/controller?action=keyeventkey&code=power"",
        You might also consider using curl instead of chrome if you don't actually need it to come up in a browser.
        Ilm HomI 1 Reply Last reply Reply Quote 0
        • Ilm HomI
          Ilm Hom @Russ
          @russ Thank You Very Much!!!! Worked with chrome, the only stranger thing is whitch before worked the other 3 times. Again thank you !!!!
