    Nothing happens when you enter the token on windows.
    • Dark OtaconD
      Dark Otacon
      I put my Token in the application on the PC, I click Sign In and nothing happens, the space to type the Token is blank again. (Token copied from Trigger instructions page)
      TRIGGERcmdAgent_QxFRvHZ1mp.png Thanks in advance for an answer ...
        Russ @Dark Otacon
        @Dark-Otacon, the interface could be better, but notice the difference between this screenshot and yours. After you input the token, the text on that window changes from, "Your token is under the "Instructions" link in your TRIGGERcmd account." to "You must subscribe before adding another computer."
        Adding more than one computer is a benefit of having an active subscription.
        ChabeticoC 1 Reply Last reply Reply Quote 0
        • ChabeticoC
          Chabetico @Russ
          @russ I formatted the pc, is there any way to pass my trigger to the "current" PC?
            Russ @Chabetico
            @chabetico, your commands were stored in the commands.json file in C:\Users\(your user)\.TRIGGERcmdData\commands.json. If that file is gone, you'll need to recreate your commands from scratch. For added security, the actual commands are not stored in your account in the cloud. They're stored on your computer.
