    SmartThings virtual devices
    • R
      richdan
      Hi
      Testing your platform with SmartThings.
      I have installed the SmartApp and can trigger the default commands (notepad, calculator) from Alexa successfully.
      1. Does your SmartApp automatically create a new virtual switch each time I create a new command in the TriggerCMD desktop app?
      2. If not, what device network ID should I assign to the new virtual devices?
      Many thanks
      Danny
        Russ @richdan
        @richdan, to add a new command, you'll need to go back into the TRIGGERcmd SmartApp and check the checkbox next to that command. That will add the command as a new virtual SmartThings switch.
        • R
          richdan
          Thanks @Russ
          I find it takes a long time from creating a command until it synchs with the TriggerCMD website. Is there anything I can do to update it faster?
            Russ @richdan
            @richdan, for me new commands sync from my PC to the website immediately so there must be a problem.
            Are you running windows? You could try restarting the agent in case it stopped working. Another thing to be aware of - if you add a background command it won't sync to the cloud unless you're running the background agent.
            • R
              richdan
              Yes, running Windows 10. It's updating immediately now. Maybe some temporary delay.
              Thanks for your help Russ.
