    Subir/Bajar Volumen en Windows con TRIGGERcmd vinculado con Alexa
    2.0k
    • raulikto _09R
      raulikto _09
      QuerrĂ­a saber como puedo hacer para que cuando le de un comando de voz a Alexa suba o baje el volumen dependiendo de lo que le haya dicho. Gracias.
        Russ @raulikto _09
        @raulikto-_09, Google Translate gave me this for what you wrote:
        "I would like to know how I can make when I give a voice command to Alexa, raise or lower the volume depending on what I have said. Thank you."
        You can use nircmd's changesysvolume option like this:
        Volume up: nircmd changesysvolume +15000
        Volume down: nircmd changesysvolume -15000
        • raulikto _09R
          raulikto _09
          I have a problem with NirCMD and it won't let me download it, when I extract the .rar it won't let me open the nircmd.exe file to put the commands. If you could help me install it, it would be of great help to me. Thank you!
            Russ @raulikto _09
            @raulikto-_09, I made this video to show you how to install nircmd.
            https://youtu.be/xub4pjenLVs
            Matias CamaletM 1 Reply Last reply Reply Quote 0
            • Matias CamaletM
              Matias Camalet @Russ
              @russ Hi! I wanted to know if there's a way to set the volume of my pc with parameters using TRIGGERcmd. I tryed but i cant find the way to set the volume in the level I want using Google Home
