    Ubuntu Linux agent instructions
    21 Posts 6 Posters 15.1k Views 1 Watching
    • P Offline
      pirates
      Is this normal?
      root@fox:~/TRIGGERcmd-Agent# npm install
      npm WARN deprecated chokidar@1.7.0: Chokidar 2 will break on node v14+. Upgrade                                   to chokidar 3 with 15x less dependencies.
      npm WARN deprecated request@2.88.2: request has been deprecated, see https://git                                  hub.com/request/request/issues/3142
      npm WARN deprecated posix-argv-parser@2.0.0: No longer maintained
      npm WARN deprecated gulp-util@2.2.20: gulp-util is deprecated - replace it, foll                                  owing the guidelines at https://medium.com/gulpjs/gulp-util-ca3b1f9f9ac5
      npm WARN deprecated gulp-util@3.0.8: gulp-util is deprecated - replace it, follo                                  wing the guidelines at https://medium.com/gulpjs/gulp-util-ca3b1f9f9ac5
      npm WARN deprecated react-tools@0.13.3: react-tools is deprecated. For more info                                  rmation, visit https://fb.me/react-tools-deprecated
      npm WARN deprecated fsevents@1.2.13: fsevents 1 will break on node v14+ and coul                                  d be using insecure binaries. Upgrade to fsevents 2.
      npm WARN deprecated har-validator@5.1.5: this library is no longer supported
      npm WARN deprecated chokidar@2.1.8: Chokidar 2 will break on node v14+. Upgrade                                   to chokidar 3 with 15x less dependencies.
      npm WARN deprecated core-js@1.2.7: core-js@<3 is no longer maintained and not re                                  commended for usage due to the number of issues. Please, upgrade your dependenci                                  es to the actual version of core-js@3.
      npm WARN deprecated buffer@2.1.13: This version of 'buffer' is out-of-date. You                                   must update to v2.8.3 or newer
      npm WARN deprecated circular-json@0.3.3: CircularJSON is in maintenance only, fl                                  atted is its successor.
      npm WARN deprecated core-js@2.6.11: core-js@<3 is no longer maintained and not r                                  ecommended for usage due to the number of issues. Please, upgrade your dependenc                                  ies to the actual version of core-js@3.
      npm WARN deprecated urix@0.1.0: Please see https://github.com/lydell/urix#deprec                                  ated
      npm WARN deprecated minimatch@0.3.0: Please update to minimatch 3.0.2 or higher                                   to avoid a RegExp DoS issue
      npm WARN deprecated resolve-url@0.2.1: https://github.com/lydell/resolve-url#dep                                  recated
      npm ERR! code EBADPLATFORM
      npm ERR! notsup Unsupported platform for node-windows@0.1.14: wanted {"os":"win3                                  2","arch":"any"} (current: {"os":"linux","arch":"x64"})
      npm ERR! A complete log of this run can be found in:
      npm ERR!     /root/.npm/_logs/2020-10-23T21_32_13_991Z-debug.log
        Russ @pirates
        @pirates, to avoid that problem, copy the ubuntupackage.json file to package.json before you run npm install. I'll update the steps above with that. It looks like the default package.json was the Windows version.
          @Russ I have this installed and functional on a Debian 10 Raspberry Pi. The default commands work great, as well as a custom one that triggers a bash script that sends a WOL command to my PC.
          Question for you: Does triggercmd run the script as root, or as the user with elevated privileges via sudo?
            @Tim-Manochehri, it runs them as root. If you run this command you'll see that the agent runs as root, and the agent runs the commands:
            ps -ef | grep triggercmdagent
            • Daniel MachínD Offline
              Daniel Machín
              I have followed the instructions in a headless Ubuntu, getting some errors:
              dpkg: error al procesar el paquete triggercmdagent (--install):
              installed triggercmdagent package post-installation script subprocess returned error exit status 127
              Triggercmd is installed but now, every time I try to apt upgrade it tries to reinstall triggercmd...
              Is this the normal behaviour?
                Russ @Daniel Machín
                @Daniel-Machín, that's not normal. I'd like to try to reproduce that problem and fix it. Can you tell me the commands you ran, and which specific operating system you installed it on? You wrote "headless" so I understand you did not install X-Windows on it.
                  Daniel Machín
                  Hi Russ,
                  Thanks for your reply!
                  System is an Ubuntu 18.04.5 LTS (bionic) without X-Windows
                  Anyway, I finally managed to make it work. Issue was dependencies:
                  apt install npm
                  solved the problem
                  Perhaps, including npm as a dependency within .deb package could solve potential future issues (currently, only nodejs is a dependency):
                  daniel@servidor:~$ sudo apt-cache depends triggercmdagent
                  triggercmdagent
                    Depende: nodejs
                  Thanks!
                  Daniel
                    Russ @Daniel Machín
                    Thanks @Daniel-Machín. Good call. I'll add that.
                    https://github.com/rvmey/TRIGGERcmd-Agent/blob/master/ubuntupackage.json#L52
                    • P Offline
                      Pr0k0 @Russ
                      @Russ One question does the agent automatically open in Linux at startup like windows? Because every time I boot I need to open it manually and it does not start up automatically. I followed the installation steps above, uninstalled, installed again but the same problem.... in windows and raspberry it is working fine with no issues... Do i need to install with no UI in Linux like raspberry??
                        Russ @Pr0k0
                        @Pr0k0, the foreground Linux agents do not run automatically in X-Windows. I researched it but couldn't find a standard way to do that. If you install the background service, that will start during boot, but you'll need to make set the "ground" field in your commands.json file to "background" instead of "foreground" because the background agent adds/removes/runs background commands.
                        • P Offline
                          Pr0k0 @Russ
                          @Russ thnx for the reply, i understand, i tried to make a .sh file to execute the application in a cronjob when boot but it does not start......i cannot understand why, if execute manually the sh file starts normally, i also tried to create a service with some name pointing to the file.....service is active but again in boot, it does not start... the problem is because in the foreground i can make routines and not need to say the computer name everytime....that's why the foreground is helpful...the background service is not visible in the Home Skills so i cannot make a routine. Anyway thanks again for the reply.
                            Russ @Pr0k0
                            @Pr0k0, background commands should show up as Alexa Smart Home devices, just like foreground commands, so I wonder if you didn't install the background service yet. This command should it:
                            • Neidson de OliveiraN Neidson de Oliveira referenced this topic on
