    Multiple IFTT accounts linked to 1 triggercmd account
    2 Posts 2 Posters 362 Views 1 Watching
    • Andrea SalveminiA Offline
      Andrea Salvemini
      Hi guys, I use TriggerCMD with Alexa but since I'm in Italy and the italian skill doesn't work properly, I use IFTT to run commands into TriggerCMD. This is also useful so I can personalize the entire phrase using Alexa's routine.
      Now the problem is that with the free account on IFTT I can only make 3 applets, so I created another account there to create one more but when I tried to link TriggerCMD to that, the first IFTT account was un-linked.
      So I guess this is because TriggerCMD gives permission to 1 account only at a time.
      Is there a way to solve this? (That's not pay for premium since I can't afford it, especially to create 1 applet more, that is all I need atm).
      Even finding something else that can communicate with TriggerCMD and Alexa.
      Thank you
        Russ @Andrea Salvemini
        @Andrea-Salvemini, you're right - you can't link two IFTTT accounts to the same TRIGGERcmd account. If you link a second account, the first account becomes un-linked.
        You don't need IFTTT though.
        I assume you're trying to use the original TRIGGERcmd Alexa skill which does not work with Alexa routines.
        The Smart Home TRIGGERcmd Alexa skill does work with routines. It simulates an Alexa Smart Home on/off switch for each of your commands, so it works with routines. You can flip the virtual switch by saying, "Alexa, turn on calculator" but you can also say whatever you want if you use a routine that flips the Smart Home switch.
