    Voice commands on Goggle Minis understood but not executing
    22 Posts 2 Posters 5.7k Views 1 Watching
      Russ @Frank Malczewski
      @Frank-Malczewski, I like the theory RF would likely be less reliable than sending the signal through your house wires.
      • Frank MalczewskiF Offline
        Frank Malczewski @Russ
        @Russ I watched the video about using Google smart home and got partly started but hit a snag not knowing what to do. I did get the service linked and now I see all my light switches in the Linked To You part of HOME, not assigned to any room. But that is where I failed to get further as I don't understand the bat files I now need to create, what folder to put them in, what to call them, and the purpose of a voice name. If I could beg for some assistance, here is what I have. On the computer called server where TC resides, I have a folder C:X10 where I stored some 34 files dealing with turning the light switches on and off. Here is just one to show the context:
        In TC GUI I have:
        Which is programmed as follows:
        I assume all these similar on/off bat files are no longer good. When I went to TC and checked into voice commands, I see a long list:
        but they don't do anything, although if I say Hey Google, turn off the kitchen sink light it says it is doing it but of course nothing happens.
        I assume the disconnect is the .bat files. Could you give the proper syntax for just one light, and the programming needed for the GUI? I assume I can leave the new bat files in the same folder. And do I need a voice name for my 'server'?ScreenShot002.jpg
        Thanks.
        And as for the command that I am using, and the question as to whether that syntax is telling the computer to send an RF signal, is there a way to port the command through AH Pro so that the command goes via the USB connection to my 15A?
          @Frank-Malczewski, you have 2 options.
          Option 1: Use your current .bat files, turn on parameters, and setup your commands like this:
          Command: c:\x10\kitchensinkon.bat
          Off Command: c:\x10\kitchensinkoff.bat
          Allow Parameters: true
          Option 2: Use one batch file for each light, and don't fill in the Off Command so the Command runs with " on" or " off" parameters.
          The batch file would insert the on or off parameter where %1 is in the .bat file. So your batch file would look like this:
          c:\Program Files (x86)\Common Files\x10\Common\ahcmd.exe" sendrf f1 %1
          Command: c:\x10\kitchensink.bat
          About sending the signal to your X10 devices through your 15 amp power line (plc) instead of over the air (rf),
          c:\Program Files (x86)\Common Files\x10\Common\ahcmd.exe" sendplc f1 on
          It's sendplc and sendrf because:
          plc = power line command
          rf = radio freqency
            @Russ Thank you! Of the two options, is one better than the other?
            And also thanks for the sendpic command. Never knew that and I bet that will resolve my failures as turning lights on/off from the program never failed...
              @Frank-Malczewski, one advantage of using one batch file is if you want to make a change there are fewer files to update, but otherwise they'll work the same. Let me know how the sendplc command works out.
                @Russ So I went with option 1. Thought it was easier and I don't plan to make many changes once done.
                And YES, the SENDPLC command seems to be working much better BUT too early to tell. I changed each .bat file over to it. Time will tell.
                Lastly, I didn't know if I needed to do something about the "VOICE NAME" column for my computer. Right now it is blank (see screenshot above). What is its purpose?
                Thanks for all your help. Hopefully this will be the last message pestering you...
                  @Frank-Malczewski, good question - the voice name field for the computer is really only needed for your non-default computer(s). Notice you don't have a "Voice Commands" or "Smart Home Voice Commands" button for serverDell. That's because it's not your default computer and you don't have a voice name for it.
                  You can run commands on your default computer by saying the command without the " on (voice name of your computer)" part.
                  If you give your serverDell computer a voice name of, "dell", you'll be able to say, "Hey Google, turn on calculator on dell."
                  If you say, "Hey Google, turn on calculator," it will run calculator on your default computer which is Server.
                  Frank MalczewskiF 1 Reply Last reply Reply Quote 1
                    @Russ Well, two steps forward but one back. I deleted all my routines for all the lights. I also purged all the extra commands in the GUI interface. But when I tell Google to turn off the computer room light, it will turn it off, turn it off, then sometimes says SORRY, CANT REACH TRIGGERCMD SMARTHOME but it still turns off the light. Or it will say SORRY, CANT REACH TRIGGERCMD and not turn it off, but then, after about 15 seconds, the light will go off. Any ideas as to what is going on? BUT on a positive note, I have significantly cleaned up all my routines in HOME and in the GUI interface, plus it is understanding what I want much better. Thanks.
                      @Frank-Malczewski, are you still getting that "CANT REACH TRIGGERCMD SMARTHOME" back from Google? I wonder if that was related to Google's recent outage. I've heard that before but for me it's been very rare.
                        @Russ Yes. Several times today I have gotten "Sorry, TrigerCMD is not available right now", including right now. Earlier, I thought it might have been something related to changes made in the GUI interface (removed a command) so I went to GOOGLE HOME and "Reconnect Account" That worked and triggerCMD started to work. But 10 minutes ago I tried to turn on a light and got the same message. So I just went into GOOGLE HOME and did the same thing as earlier. And yes, the light command now worked. Have any idea what is going on? having to constantly Reconnect Account is a pain. Thanks.
                          @Frank-Malczewski, thanks for telling me about this. I'll see if I can figure out why that's happening.
                          You could help me by posting the exact time you hear the error, and your time zone. That way I can find the relevant log entries.
                          EDIT: I was able to reproduce it and I think I know what the problem is. Sometimes my server is failing DNS lookups. My server needs to contact Google after Google contacts my server, and I think sometimes that DNS lookup is failing. I think I have a solution. I'm working on it now.
                          EDIT2: @Frank-Malczewski, it's fixed now. I have a workaround in place for the DNS problem. I have a longer term fix too but it will take longer than tonight to implement. Please test it.
                          EDIT3: Nevermind. I thought I had it but apparently not. I just tested it and had the same problem - "Sorry, it looks like TRIGGERcmd Smart Home is unavailable right now," or ,"Sorry, I couldn't reach TRIGGERcmd Smart Home"
                          EDIT4: I found another DNS name it was trying to go to and I added it to the workaround (/etc/hosts). I haven't been able to reproduce the problem since, but it's intermittent, so I'm not sure whether it's fixed or not yet.
                            @Russ Thanks Russ. I am glad it is nothing wrong that I am doing. FYI, for the past 24 hours, it has been stable with no error message. Hopefully, you will find the ultimate issue.
                            New question - when my wife tries to tell Google to turn on / off a light, it fails. Yet in HOME, it does show her as being a 'connected account' in the Google Nest hub. Any idea what I need to do to allow her to be able to control lights?
                            Thanks.
                              @Frank-Malczewski, please take a look at these thread about this:
                              https://www.triggercmd.com/forum/topic/363/google-home/22
                              https://www.triggercmd.com/forum/topic/526/now-you-can-share-your-computers-with-other-triggercmd-users
                              TL;DR:
                              I suspect you have voice match on. So you could setup a TRIGGERcmd account for her and share your computers with her.
                                @Russ Hi Russ, ol' buddy, ol' pal... 🙂
                                Well, as before, I got part of way through. I read the above, decided to not disable voice match and therefore go the route to add her. I was successful in creating her new account, used the email feature to her and accepted it in her account, and server does show up under her new triggercmd account (used google login method since I already have that account 'linked' to all the HOME devices. But when I looked at the voice command page, I saw nothing. When she tried to turn off a light, she got "Looks like TC is not available right now", so I must have missed a step.
                                And to make matters worse, when I tried to turn off the same light, I got "Sorry, I couldn't reach TC Smarthome right now". It was at 8:15PM, EST.
                                EDIT: Just tried to update Agent, then remove and reinstall background service. I then went to HOME and reconnected the account. In the past, this made it work for me. Right now, it is not working ("Sorry, I couldnt reach..."). And I did reboot the server after starting up the background service.
                                EDIT2 If I go to triggercmd.com I can execute triggers...
                                So, did I miss a step or is it that same problem as I had before?
                                Thanks.
                                RussR Frank MalczewskiF 2 Replies Last reply Reply Quote 0
                                  For anyone reading this, @Frank-Malczewski and I talked. It turned out his wife's Google Home account was linked to @Frank-Malczewski's TRIGGERcmd account. That actually prevented both accounts from running any commands.
                                  This is how it needs to be:
                                  • Frank's Google Home account -> Frank's TRIGGERcmd account
                                  • Frank's Wife's Google Home account -> Frank's Wife's TRIGGERcmd account
                                  He also set Server (his only computer) as her default computer in her TRIGGERcmd account.
                                  Thanks again Frank! I'm glad we got that figured out. I was worried. I'll try to make this clearer in my posts about how the Google Assistant TRIGGERcmd action linking works.
                                    Frank Malczewski @Frank Malczewski
                                    @Frank-Malczewski For anyone reading this post, we solved the problem.
                                    Before I followed the instructions above for sharing my computer with my wife (creating a triggercmd account for her and sharing my computer), I had tried to add her to MY triggercmd account by going on HER phone to HOME / SETUP DEVICE / WORKS WITH GOOGLE and linked to TriggerCMD Smart Home, which it accepted. But after following Russ' process for sharing the computer, neither of us could use Google to turn stuff on or off.
                                    What I had to do is DISCONNECT TriggerCMD Smart Home on HER phone, then reconnect it so it picked up her new triggercmd.com account. You cannot have two people trying to access the same account.
                                    Problem solved and now we both can talk to Google to turn lights on and off.
                                    Thanks Russ for working with me on this...
                                    EDIT: I see that Russ also posted that we solved this! We must have been typing at the same time...
