    Turn on a plug wifi with this program?
    • JAIME FLORESJ
      JAIME FLORES
      Is there a way to know what is the percentage of the laptop battery? I want to make a wifi socket turn on when the laptop battery is at 10%, I want to connect the charger to that socket and when the battery is at 100% it turns off. is this possible with this program? or does anyone know how i could do it?
        Russ @JAIME FLORES
        @JAIME-FLORES, I found this batch file that can tell you your remaining battery life:
        http://www.robvanderwoude.com/files/battstat_xp.txt
        I'm not sure you'd need TRIGGERcmd for this, but you could probably schedule a script to run every minute or so that checks your battery life, then if it's at 10 percent, call an API to turn on the wifi plug.
        • JAIME FLORESJ
          JAIME FLORES
          Thank you very much Russ 😄 . I will try it. Have an excellent day
          • SAMUEL KRAMER SCHWIDERKES
            Hello. Work this integration? Why is the update's?
              Russ @SAMUEL KRAMER SCHWIDERKE
              @SAMUEL-KRAMER-SCHWIDERKE, are you asking if this works?
              When I answered @JAIME-FLORES before, I hadn't actually tried it. Just now I tried that script and it didn't work for me. So I'm sorry about that.
              I like @JAIME-FLORES's idea - to save electricity by leaving his laptop disconnected from power until the battery gets low.
              I found another way to detect your battery laptop's battery charge. You could use Nirsoft's batteryinfoview tool to read your battery's remaining life with a command like this:
              batteryinfoview /scomma c:\stuff\battery.txt
              Then when the battery gets low you could call an IFTTT webhook event that turns your wemo plug on.
