    Open hyper terminal in windows
    4 Posts 2 Posters 3.7k Views 1 Watching
    • Lucas CamilaL Offline
      Lucas Camila
      Hi! I'm running Windows 10...How can I open Hyper and run command?
        Russ @Lucas Camila
        @Lucas-Camila, how did you get Hyper Terminal on Windows 10? I thought Microsoft discontinued it.
        Anyway, if you can find the .EXE, you could run it using its full path as the command. Something like this:
        "C:\Program Files (x86)\HyperTerminal\HyperTerminal.exe"
          Lucas Camila
          Yes, i use Hyper Terminal with wsl...
          How can I run a command after opening the terminal?
            Russ @Lucas Camila
            @Lucas-Camila, is this the Hyper terminal you're talking about? https://hyper.is/
            One option is you could add hyper to the end of your ~/.bashrc file to run it when you start WSL.
            This command can open WSL for you:
            start wsl
            For what it's worth I also noticed you can run bash scripts in WSL from TRIGGERcmd with a command like this:
            bash /home/russ/script.sh
