    Help with Alexa - TriggerCMD
    15 Posts 2 Posters 3.1k Views 1 Watching
      Russ @gfmendes
      @gfmendes, with the TRIGGERcmd Smart Home skill, if you setup your command like this, with Allow Parameters = true and an Off Command set, then you can say, "turn on calculator" to run calc and "turn off calculator" to run taskkill /f /im calculator.exe to close it.
      If you have Allow Parameters = false, it will run calc whether you say turn on or turn off calculator because it blocks the on or off parameter coming from the skill.
      • G Offline
        gfmendes @Russ
        @Russ said in Help with Alexa - TriggerCMD:
        Hey @Russ , tks for this fast answer.
        I did exactly what you said to me, and I still have the same problem. On my cellphone notification pops up "to turn on this trigger say it 'turn OFF and the name of the trigger', but Alexa's voice say "to turn on this trigger say it 'turn ON and the name of the trigger'.
        I don't know why the commands are reversed yet. Alexa's voice says one thing (to activate the command, use "turn on") and alexa's notification says another (to activate the command, use "turn off"), and the trigger only activates if I use "turn off".
        • G Offline
          gfmendes @gfmendes
          @Russ,
          I think that i discovered the problem. I switched my Alexa to English and the commands worked. But I live in Brazil, does the APP not work here in Portuguese?
          Tks
            Russ @gfmendes
            @gfmendes, yes, it works in Brazil in Portuguese.
            Have you seen this video?
            You should be able to say these things:
            • ligue a calculadora
            • desligue a calculadora
            Both ligue and desligue should run the command, unless you use the Off Command field, in which case desligue should run that one.
            • G Offline
              gfmendes @Russ
              @Russ, yes, I've seen this video, I even used it to configure my Alexa and TriggerCMD.
              I'm using the Off Command field like you said, but not worked yet with Portuguese commands with "ligue" and "desligue" not even with the Calculator or Notepad.
              Do u have another ideia about it?
              Tks
                Russ @gfmendes
                @gfmendes, please confirm you're using the Smart Home skill.
                Original skill: https://www.amazon.com.br/gp/product/B074TV61DK
                Alexa, pergunte Execute Comando executar calculator
                Smart Home skill: https://www.amazon.com.br/VanderMey-Consulting-LLC-TRIGGERcmd-Smart/dp/B07P1MMFRP
                Alexa, ligar/desligue calculator
                EDIT: I had the url's backward at first. I corrected them above.
                • G Offline
                  gfmendes @Russ
                  I'm using this skill
                  Original skill: https://www.amazon.com.br/VanderMey-Consulting-LLC-TRIGGERcmd-Smart/dp/B07P1MMFRP
                  Could u confirm that I'm right please?
                  Tks
                    Russ @gfmendes
                    @gfmendes, sorry, I had the URL's backward at first. I fixed them. That's URL is for the Smart Home skill that allows you to say, "ligar/desligue calculator" because your commands become Alexa smart home devices.
                    Please tell me if you see your commands as devices here:
                    They should look like this:
                    • G Offline
                      gfmendes @Russ
                      No problem. Am'i using the right skill?
                      If i "play" any trigger on site, they run it, but no way using voice.
                      Take a look. They are like this.
                        Russ @gfmendes
                        @gfmendes, please try changing your command's voice word, and verify it updates the Alexa device you showed in the screenshot.
                        Yes that is the right skill for running commands as if they were switches you can have Alexa turn on and off.
                        • G Offline
                          gfmendes @Russ
                          @Russ , my Alexa was with the last version and i tried all this things.
                          Looking how to unlock new skills to Alexa, i changed my Amazon Account to USA, and now "ligar/desligar" are fuction very well!
                          @Russ thank u so much for all your help.
                            Russ @gfmendes
                            @gfmendes, thank you. How did you change your Amazon account to USA? I'd like to switch mine to Brazil to see if I can reproduce and fix the problem.
                            • G Offline
                              gfmendes @Russ
                              @Russ Try this
                              Manage Your Content and Devices > Preferences > Country/Region Settings
                              You will need to put any andress here in Brazil to change. Your kindle account comes too if u want.
                              If u need help with Portugues or test, let me know.
                              @Russ, another question. Why to open some triggers, I need to use differents activation words? Like 'ativar', 'abrir', 'ligar'
                              Some triggers i can use 'ativar', others 'abrir' because they don't understand 'ativar'.
                                Russ @gfmendes
                                Thanks @gfmendes. I don't know why certain words would work better. The TRIGGERcmd Smart Home Alexa skill simulates a light switch for each command, so I thought ligar and desligar would work best. Google Translate tells me those are the translations for "turn on" and "turn off" which is how I tend say it in English. I can also say, "calculator off".
                                This page gives some background too if you're interested:
                                https://www.amazon.com.br/gp/help/customer/display.html/ref=hp_bc_nav?ie=UTF8&nodeId=201749260
