    Trigger an Alexa or SmartThings device?
    2 Posts 2 Posters 607 Views 1 Watching
    • T Offline
      TomberWolf
      Dear community,
      I'm completely new with TRIGGERcmd, so please excuse if this was asked before, I wasn't able to find something about that.
      I want TRIGGERcmd to trigger an Alexa device or a SmartThings (virtual)device to be able to switch off a smart plug after the PC was shutted down.
      Is this possible?
      Stay healthy and best regards
      Tom
        Russ @TomberWolf
        @TomberWolf, good question. You can have TRIGGERcmd run a "curl" command that calls the IFTTT Webhooks API to run an applet that turns your SmartThings switch on.
        You'll need your IFTTT webhooks key, which you can get at this page:
        https://ifttt.com/maker_webhooks/settings
        You'll see a URL like this: https://maker.ifttt.com/use/**asdfasdfblahblah**
        The bold part of that URL is your webhooks key.
        Setup a TRIGGERcmd command like this, where front_light is your Webhook applet's Event Name.
        curl https://maker.ifttt.com/trigger/front_light/with/key/asdfasdfblahblah
        When you make your applet, search for Webhooks as your This part.
        If you use Windows, you can download curl from here.
