    Alexa invocation and SmartThings switch questions
    19 Posts 5 Posters 12.7k Views 2 Watching
      Russ @Nate Hales
      @Nate-Hales, I knew you'd have some use cases for this.
      • N Offline
        Nate Hales @Russ
        @Russ .... I vote to be able to get rid of the computer name "DS" at least for the default computer. .. Alexa, turn on Kodi
        Alexa, turn off Kodi
        Maybe only add the computer name f people have more than one computer. I bet 99% of us only use one main computer.
          Russ @Nate Hales
          @Nate-Hales, I think you're right. I'll work on it.
          • N Offline
            Nate Hales @Russ
            @Russ If trigger does not force the Default computer name into the name of the smartthings switch ... then my Alexa would throw the smartthings switch no problem. 🙂
              This rocks! I am totally launching games like this. "Alexa, Turn on Rocket League". It will also be great for when I rage quit "ALEXA, TURN OFF ROCKET LEAGUE!"
              • N Offline
                Nate Hales @Guest
                @Matthew-Cole hahah
                • N Offline
                  Nate Hales @Russ
                  @Russ STOP CODING!! IT WORKS HOW I WANT ALREADY 🙂 @Neflhiem will like this as well because he can now just speak the name of the switch (without saying anything before it) https://www.triggercmd.com/user/computer/list <--- In here:
                  I just deleted my computer name (made it blank) and the voice name blank (I had to put one in space-bar to allow it to save) .
                  • N Offline
                    Nate Hales
                    What am I doing wrong? I am trying to make a .bat file to turn on and off my x-10 lamps... I kinda have no clue how to set up parameters... I just tried to copy you. 🙂 0_1507784819049_Param.jpg
                      Russ @Nate Hales
                      @Nate-Hales, your batch file needs == where you have Front Room Lamps
                      if "%1"=="on" curl http://.....%%22A6%%20off%%22
                      if "%1"=="off" curl http://.....%%22A6%%20off%%22
                      Sorry I was lazy and didn't want to type your full URL but I think you know what I mean. The double % signs are to "escape" your % signs so the batch file parser doesn't think %2 is your second parameter.
                        Russ @Nate Hales
                        @Nate-Hales, I see what you mean, but there are people with multiple computers (like me) who need to have a actual computer names (not space) to distinguish them.
                        I think I like your original idea - to leave the computer name out of the virtual switch name if it's your default computer.
                        I'm glad you have a work-around in the meantime. I might not have time to finish this change until this weekend. We'll see. I'm eager to get it done.
                          wow... well i know what ill be doing tonight when i get in! this looks great @Russ ! Im not good with command line stuff but this looks simple enough to figure out. With all the conversation here it looks like i can pretty much set up everything to work perfectly.. So glad i dropped in to figure this out.. You rock.
                            Thanks @Neflhiem!
                            BTW, now the virtual SmartThings switches for your default computer are named without your computer name. The switches for your non-default computer still have the computer name prefix.
                            Next I'd like to make it so if you only have one computer, then it's automatically your default computer. I should have done that a long time ago.
                              Got it up and running. Man.. this is friggin perfect. Seriously.. perfect.
                                @Neflhiem, I'm glad you got it working. I like how it turned out too. Thanks again for your questions - I wouldn't have thought to implement this if you hadn't asked.
