    How to connect the PC after sleep mode
    Mac
    1.7k
    • RobertofilhoR
      Robertofilho
      Which command can I put for my PC to return from sleep
      started sleep mode:
      Command:pmset sleepnow
      which command can i return?
      Qual comando posso colocar no meu PC para retornar do modo de suspensão?
      iniciou o modo de suspensão:
      Comando: pmset sleepnow
      qual comando posso retornar?
        Russ @Robertofilho
        @Robertofilho, you can't run commands on your computer when it's in sleep mode, so you would have to use another computer on your network to send it a wake-on-lan magic packet to take it out of sleep mode first.
        What you could do is use these commands to turn the display off and on:
        Display off:  pmset displaysleepnow
        Display on:   caffeinate -u -t 1
        • Rafael SathlerR
          Rafael Sathler
          Tentei criar a programação usando este comando que vc informou, mas não consegui nem mesmo suspender. Onde encontrou este comando?
            Russ @Rafael Sathler
            @Rafael-Sathler, I just realized these are Mac commands and the topic was in the Windows section, so I moved this over to the Mac section.
            I wonder if that's where the confusion came from.
