    Feature request: move [params] to a different spot
    feature request
    • M
      mikey186
      I've been using TriggerCMD since it had appeared as a IFTTT service, and frankly I like when I use the parameters in a CMD/PowerShell. Now, I would really wish if there's a way to move the [params] variable to a different section. For instance, I want the command to restart OR shutdown in 5 minutes. The way I want it to work would be something like shutdown [params] /t 5. When I tried to add the placeholder myself, with Allow Paramaters to true, there is 2 param duplicates such as shutdown [params] /t 5[params]. Is there a way to do that? If not, please have that feature in the near future.
        Russ @mikey186
        @mikey186, that's an interesting idea. I made it so the parameters get tacked on to the end of your command after a space because the use-case I envisioned was a bash, batch, or powershell script. Scripts allows you to use the script execution parameters anywhere in the commands, for example my TRIGGERcmd command could be c:\scripts\shutdown_or_reboot.bat and the batch script would have these contents:
        shutdown %1 /t %2
        Then I could remotely specify whether to reboot or shutdown, and specify how many seconds:
        • Reboot in 10 seconds: c:\scripts\shutdown_or_reboot.bat /r 10
        • Shutdown in 5 seconds: c:\scripts\shutdown_or_reboot.bat /s 5
        So you can already do what you want to do, but I see value in your feature request because you could do the same thing without having to write a script. I would probably implement with placeholders for each parameter with syntax similar to the Voice Reply field, like this:
        TRIGGERcmd command: shutdown {{param1}} /t {{param2}}
        What do you think?
        • M
          mikey186 @Russ
          @Russ I like the idea. Though with two parameters (maybe more if needed)? That would be even more better with an ultimate advantage. Especially if I have a backup program (like AOMEI Backupper with cmd prompts OR a BAT script w/parameters on top).
          Although one way I would wish it would be better is if there is a TriggerCMD exe to execute the CMD commands. For instance, in AOMEI backupper, I want to send the post-command to TriggerCMD to fire up the script.
          alt text
            Russ @mikey186
            @mikey186, you want the backup program to run a command on a remote computer via TRIGGERcmd at the end of a backup job? If not, please explain more about what you want to do.
            • M
              mikey186 @Russ
              @Russ no, simply when a backup is completed, I want the post-command to send it to TriggerCMD to launch the cmd script.
                Russ @mikey186
                @mikey186, I'm probably missing something, but if the cmd script is local to the computer running the backup, it seems to me you don't even need TRIGGERcmd - you could just make the post-backup command run the cmd script.
                If you do want to use TRIGGERcmd though, you could make the post-backup command run the tcmd utility that can run any of your TRIGGERcmd commands - on a local or remote computer.
                • M
                  mikey186 @Russ
                  @Russ well never mind, I manage to find a workaround. But I would hope to see a advantage to move the PARAMs and/or more PARAMs in the future. It would be interesting.....
