    Linux VM - TriggerCMD shows messages like it's working, but commands don't actually execute
    33 Posts 2 Posters 9.9k Views 1 Watching
    • J Offline
      Joe @Joe
      @Russ follow-up question on hello_world.sh:
      When I set the appending to a "hard" directory like /tmp, it works fine
      When I point it to my automounted home area path a-la:
      #!/bin/bash
      echo Hello World >> /home/<my_user_name>/xxxx.txt
      nothing happens and/or xxxx.txt doesn't seem to land anywhere.
      Does agent.js / TriggerCMD not like automounted directories?
        Russ @Joe
        @Joe, about the automounted directory, is it available to root? I ask because I suspect your background service is running as root. I see from your commands.json file in your screenshot that all of your commands are set to background, so they would only run in the context of your background service.
        In fact that's probably why you're not seeing those gnome apps. For those to run and be viewable, you'd need to run the agent in an X terminal in foreground mode (which is the default mode if you just run triggercmdagent). And, your commands would have to be foreground commands.
        The agent running in one mode won't run commands that are set to run in the other mode. It will log when you trigger them though.
        Another thing to consider. If you run the agent as a different user, it will create a new computer in your account because if it doesn't find a ~/.TRIGGERcmdData folder, it creates one with a fresh computer ID and creates the computer in your account with that ID. You could get around that by copying your .TRIGGERcmdData folder from /root to your user's home folder so it would connect with the same computer ID.
        If your automounted home folders are available to root, then your hello world script should be able to write to those home folders with the background service running as root.
        You probably know this, but you can switch to root with this command, then do an ls to see if you can see those home folders:
        sudo su -
        • J Offline
          Joe
          Thanks for the detailed update, @Russ !!!
          A) I do now see the "fresh" xxxx.txt in the /root directory after a "sudo su -"
          B ) Doesn't triggercmdagent need to be run as root (certainly it seemed to be a requirement for the install)? If not / presuming your comment on "you'd need to run the agent in an X terminal in foreground mode" means "no root, just run triggercmdagent as 'yourself'", I get this error when I try to run triggercmdagent as me in my home directory:
          [jhupcey@orw-mobile-vm ~]$
          [jhupcey@orw-mobile-vm ~]$ triggercmdagent &
          [1] 19056
          [jhupcey@orw-mobile-vm ~]$ /usr/share/triggercmdagent/triggercmdagent: symbol lookup error: /usr/share/triggercmdagent/triggercmdagent: undefined symbol: gtk_widget_get_scale_factor
          [1]    Exit 127                      triggercmdagent
          C) A parallel interpretation of your above comment was to also:
          C.1 -- As root/sudo: edit root's commands.json to make gedit and calc be "foreground"
          C.2 -- As me, do a cut&paste of this revises commands.json into a vi editor, "copy" root's commands.json to /home/<my_user_name>/.TRIGGERcmdData directory so the "new" commands.json will clearly be in my personal account ownership
          C.3 -- Expect that triggercmdagent will pickup on this new, "local" overlay
          This yielded no change in behavior (I got the encouraging trigger message but still no calc popping up), and this I freely acknowledge I am still not getting it unfortunately.
          D) How should I proceed? Do some sort of uninstall, re-install, edit some config file, or what? Help!
          Joe
            Russ @Joe
            @Joe, why did you add a & to the end of the triggercmdagent command? If you leave that off, it should run the agent in foreground mode and you'll be able to see the output.
            Please try running triggercmdagent in an xterm window as yourself, and trigger your foreground commands on the computer in your account that got created when you ran it as yourself (not the one created when you ran it as root).
            If you want to start from scratch, there's no need to re-install. Just delete the ~/.TRIGGERcmdData folder, and the computer in your account that matches the ID in ~/.TRIGGERcmdData/computerid.cfg. Then when you run triggercmdagent, it will prompt you again for your token, then create a new computer and .TRIGGERcmdData folder.
            • J Offline
              Joe
              Regarding:
              Force of habit. Apologies.
              Looking to start from scratch per your guidelines:
              • I deleted the ~/.TRIGGERcmdData folder in my home area
              • I also went my https://www.triggercmd.com/user/computer/list and deleted the Linux VM I'd been working with
              • Next, I run % triggercmdagent in the foreground, but I get the following error almost immediately:
              What next?
              J 1 Reply Last reply Reply Quote 0
              • J Offline
                Joe @Joe
                Edited to add: presuming there are no more easy tweaks to be made here, I'm willing to do a complete re-install from scratch and potentially save us all some time. Please advise.
                While I have the floor: FYI, some background on my objectives here:
                • The baseline need is to launch a program tool from the command line with an Alexa voice command in my Linux VM
                • Next, once the given tool(s) GUIs are open, I'd use voice commands to launch pre-made "do files" to execute specific flows in the tool(s)
                • In a perfect world, I'd also be able to map Alexa voice commands to "macros of menu commands" similar to what you can do with WSH in MS Windows
                  Russ @Joe
                  @Joe, you might want to try a fresh VM or uninstall/reinstall because I'm not familiar with that gtk_widget_get_scale_factor error.
                  Another way to run the agent is this:
                  That path assumes Ubuntu. If that works, you might be able to salvage your install.
                  • J Offline
                    Joe
                    Thanks, @Russ !
                    The VM is Red Hat Enterprise 7.1, but I tried the "node" command you cited above anyway.
                    The result:
                    • a new "Computer" did appear in https://www.triggercmd.com/user/computer/list, but no Triggers appeared.
                    • Interesting that Alexa still gave me a hearty "Ok" when I asked for "Hello World" and "Calculator", but nothing happened
                    At this point I think it's best to go ahead and do a full UNinstall, contemplate all the advice you've provided above, then do a fresh reinstall.
                    Any tips for a complete, scorched earth TriggerCMD UNinstall on this Red Hat Linux VM before I do a reinstall?
                    P.S. For anyone else following this thread, my TriggerCMD instances on my Raspberry Pi and MS Windows machine are doing fine. I think this Linux dust-up is simply due to my relative inexperience dealing with a Red Hat VM distro
                      Russ @Joe
                      @Joe, it could be that the reason Alexa said "OK" was you're using the Smart Home skill and she still thinks you have some "devices" there. The way to fix that is to go here and click Remove All, then Discover. I've done my best to synchronize the commands with your Alexa devices, but there are still scenarios where they can get out of sync. This is one reason you should test in this order:
                      1. Use the green play button in the GUI editor if you're using it.
                      2. Use the green Trigger button on the website.
                      3. Use Alexa
                      You could try this procedure to re-install the agent, but you might need something more dramatic, like a fresh VM.
                      • J Offline
                        Joe
                        Thanks again, @Russ for the support and the added tech tips!
                        I'll do a reinstall and report back.
                        • J Offline
                          Joe
                          Update: unfortunately, no luck on the re-install of the triggercmdagent-1.0.1.x86_64.rpm
                          First, I'm not seeing the Linux VM "Computer" getting re-listed in https://www.triggercmd.com/user/computer/list
                          When I run triggercmd agent as me after the re-install I get the now familiar error:
                          For the heck of it I also have logged into another window as root, and executing triggercmdagent in /root does nothing. For curiosities sake / playing a hunch, I cd'ed into .TRIGGERcmdData, and ran the triggercmdagent.service, and at least I get the following more promising error messages:
                          [root@orw-mobile-vm ~]#
                          [root@orw-mobile-vm ~]# pwd
                          /root
                          [root@orw-mobile-vm ~]# cd .TRIGGERcmdData/
                          [root@orw-mobile-vm .TRIGGERcmdData]# ls -la
                          total 32
                          drwxr-xr-x   2 root root 4096 May 23 15:06 .
                          dr-xr-x---. 23 root root 4096 May 23 14:52 ..
                          -rw-r--r--   1 root root  384 May 20 22:31 commands.json
                          -rw-r--r--   1 root root  384 May 23 15:06 commands.json.backup
                          -rw-r--r--   1 root root   24 May 17 19:07 computerid.cfg
                          -rw-r--r--   1 root root  516 May 17 19:07 sendresult.sh
                          -rw-r--r--   1 root root  148 May 17 19:07 token.tkn
                          -rwxr-xr-x   1 root root  230 May 17 19:26 triggercmdagent.service
                          [root@orw-mobile-vm .TRIGGERcmdData]# ./triggercmdagent.service
                          ./triggercmdagent.service: line 1: [Unit]: command not found
                          ./triggercmdagent.service: line 2: Agent: command not found
                          ./triggercmdagent.service: line 4: [Service]: command not found
                          Running Linux daemon to run background tasks.
                          Logging in with saved token to run background tasks.
                          Write backup completed.
                                   Connected at: Sat May 23 2020 15:19:16 GMT-0700 (PDT)
                          Initiated command removals
                          { message: 'Subscribed to 5ec1edf375b86f0019cd1a2c!' }
                          Initiated command adds
                          Failed while trying add a trigger.
                          Am I getting any closer, or am I just embarrassing myself at this point?
                            Russ @Joe
                            @Joe, can you try this command? After googling that error I think it's basically saying it can't run the Chromium based GUI portion of the agent. This command runs the agent without the GUI:
                            triggercmdagent --console
                            Also I saw that it couldn't add a trigger. To fix that you could start fresh by deleting your .TRIGGERcmdData folder and the computer in your account.
                            • J Offline
                              Joe
                              Here is the result (run as me, not as root -- for root nothing happens):
                              [jhupcey@orw-mobile-vm ~]$ triggercmdagent --console
                              squirrelEvent --console
                              /usr/share/triggercmdagent/triggercmdagent --console: symbol lookup error: /usr/share/triggercmdagent/triggercmdagent --console: undefined symbol: gtk_widget_get_scale_factor
                              Possibly related: looking at the timestamps in /root/.TRIGGERcmdData (above) all the timestamps are from the initial install. My point being: whatever I run as me, does it get superceeded by this "stale" root stuff ? Hence, to do a pure UNinstall, should I do some sort of "rm -r" all this, stop some systemctl service, rm -r the <my_home>/.TRIGGERcmdData?
                              • J Offline
                                Joe
                                Update: apologies -- I didn't see the second part of your prior comment.
                                I will delete both the root and my .TRIGGERcmdData folders and start over.
                                Stay tuned ...
                                • J Offline
                                  Joe
                                  Update:
                                  So I blew away the root and my own .TRIGGERcmdData directories, and did a fresh "yum" install. It asked me for my token, etc.
                                  The good news is the "Computer" as reappeared in the list. However, no triggers are there.
                                  Back on the Linux VM:
                                  I still get the familiar error message:
                                  and I also tried running agent.js directly as noted above, and got this:
                                  [jhupcey@orw-mobile-vm src]$ pwd
                                  [jhupcey@orw-mobile-vm src]$ node agent.js --console
                                  Daemon install: false
                                  Logging in with saved token.
                                  Checking if the  computer exists.
                                  Tokenfile: /home/jhupcey/.TRIGGERcmdData/token.tkn
                                  ComputerIDfile: /home/jhupcey/.TRIGGERcmdData/computerid.cfg
                                  SyntaxError: Unexpected end of JSON input
                                      at Object.parse (native)
                                      at updateCmds (/usr/share/triggercmdagent/resources/app/src/agent.js:429:24)
                                      at /usr/share/triggercmdagent/resources/app/src/agent.js:274:5
                                      at initFiles (/usr/share/triggercmdagent/resources/app/src/agent.js:124:3)
                                      at foreground (/usr/share/triggercmdagent/resources/app/src/agent.js:270:3)
                                      at /usr/share/triggercmdagent/resources/app/src/agent.js:164:13
                                      at Request._callback (/usr/share/triggercmdagent/resources/app/src/agent.js:239:11)
                                      at Request.self.callback (/usr/share/triggercmdagent/resources/app/node_modules/request/request.js:185:22)
                                      at emitTwo (events.js:106:13)
                                      at Request.emit (events.js:191:7)
                                  Restoring the last known good file
                                  Restore backup completed.
                                  • J Offline
                                    Joe
                                    Edited to add, since the above called out a JSON error, be advised I haven't touched commands.json in either root or my home area
                                    The root commands.json is the default from the install, and the commands.json in my area is 0 bytes/empty
                                      Russ @Joe
                                      @Joe, I'm glad you tried running node agent.js --console
                                      That's very strange that it couldn't parse the commands.json file. Please try this:
                                      cp /usr/share/triggercmdagent/resources/app/src/linuxcommands.json /home/jhupcey/.TRIGGERcmdData/commands.json
                                      Then re-run that node agent.js --console command.
                                      Also, please show me the output of this command. I'd like to know what version of node js you're running:
                                      node -v
                                      • J Offline
                                        Joe
                                        @Russ, here are the results -- all run as me in my home directory:
                                        [jhupcey@orw-mobile-vm ~]$ pwd
                                        /home/jhupcey
                                        [jhupcey@orw-mobile-vm ~]$ cp /usr/share/triggercmdagent/resources/app/src/linuxcommands.json /home/jhupcey/.TRIGGERcmdData/commands.json
                                        [jhupcey@orw-mobile-vm ~]$ node agent.js --console
                                        module.js:471
                                            throw err;
                                        Error: Cannot find module '/home/jhupcey/agent.js'
                                            at Function.Module._resolveFilename (module.js:469:15)
                                            at Function.Module._load (module.js:417:25)
                                            at Module.runMain (module.js:604:10)
                                            at run (bootstrap_node.js:393:7)
                                            at startup (bootstrap_node.js:150:9)
                                            at bootstrap_node.js:508:3
                                        [jhupcey@orw-mobile-vm ~]$ node -v
                                        v6.10.2
                                          Russ @Joe
                                          @Joe, sorry I meant for you to be in the src directory when you run the agent.js file like you where earlier.
                                          That node version seems old. I'll try that version myself and see if I get a .json parse problem.
                                          EDIT: I tried node v6.10.2 and it worked fine for me, so that's not the reason for the .json parsing problem.
                                          • J Offline
                                            Joe
                                            Thanks for the update, @Russ!
                                            First, this isn't super urgent, so please enjoy the holiday weekend and we'll reconnect Tuesday
                                            Since I had basic functionality working before the "uninstall" (which I could live with at a "work around" level of functionality to get my project going), it suggests that the uninstall process / guidelines are missing steps to get me back to time zero. Hence, I ask, before I do another fresh RPM re-install:
                                            • What are all the directories and files I need to remove -- both in the root areas, and in a user home area?
                                            • What daemons and other processes need to be killed?
                                            Joe
