    Raspberry Pi install failed
    Raspberry Pi
    2.4k
    • A
      Antonio36996
      I get this errors while trying to install triggercmdagent in my raspberry pi zero (no wifi version, running with eth cable), I have installed everything you said in last posts, npm, nodejs... Everything. Tried rebooting, reinstalling npm, nodejs, triggedcmdagent... and everything gets to the same point.
      Thanks.
      pi@raspberrypi:~ $ sudo apt-get upgrade
      Reading package lists... Done
      Building dependency tree
      Reading state information... Done
      Calculating upgrade... Done
      0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
      1 not fully installed or removed.
      After this operation, 0 B of additional disk space will be used.
      Do you want to continue? [Y/n] y
      Setting up triggercmdagent (1.0.1) ...
      Directory 'node_modules' exists. Running 'npm rebuild'
      dpkg: error processing package triggercmdagent (--configure):
      installed triggercmdagent package post-installation script subprocess returned error exit status 1
      Errors were encountered while processing:
      triggercmdagent
      E: Sub-process /usr/bin/dpkg returned an error code (1)
        Russ @Antonio36996
        @Antonio36996, can you send me the output of this command?
        dpkg -i triggercmdagent_1.0.1_all.deb
        Also, please try an uninstall and re-install like this:
        apt remove triggercmdagent
        triggercmdagent
        (CTRL-C)
        I tried a fresh install using setup.bat with this method and it worked.
        I also tried installing using the original method after a fresh Raspbian install and that worked for me too.
        EDIT: Another idea - please try this and let me know what you see.
        cd /usr/share/triggercmdagent/app
        npm install
        • A
          Antonio36996
          This is the output, thanks
          sudo dpkg -i triggercmdagent_1.0.1_all.deb
          (Reading database ... 51918 files and directories currently installed.)
          Preparing to unpack triggercmdagent_1.0.1_all.deb ...
          Unpacking triggercmdagent (1.0.1) over (1.0.1) ...
          dpkg: error processing package triggercmdagent (--install):
          triggercmdagent
          pi@raspberrypi:~ $ cd /usr/share/triggercmdagent/app
          pi@raspberrypi:/usr/share/triggercmdagent/app $ npm install
          pi@raspberrypi:/usr/share/triggercmdagent/app $ cd ~
          pi@raspberrypi:~ $ sudo dpkg -i triggercmdagent_1.0.1_all.deb
          triggercmdagent
          pi@raspberrypi:~ $ sudo systemctl stop triggercmdagent
          Failed to stop triggercmdagent.service: Unit triggercmdagent.service not loaded.
          pi@raspberrypi:~ $ sudo /usr/share/triggercmdagent/app/src/removedaemon.sh
          pi@raspberrypi:~ $ sudo apt remove triggercmdagent
          The following packages will be REMOVED:
          triggercmdagent
          0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
          Removing triggercmdagent (1.0.1) ...
          Selecting previously unselected package triggercmdagent.
          (Reading database ... 49379 files and directories currently installed.)
          Unpacking triggercmdagent (1.0.1) ...
          triggercmdagent
          pi@raspberrypi:~ $ triggercmdagent
          pi@raspberrypi:~ $ sudo /usr/share/triggercmdagent/app/src/installdaemon.sh
          cp: cannot create regular file '/root/.TRIGGERcmdData/triggercmdagent.service': No such file or directory
          /usr/share/triggercmdagent/app/src/daemonmgr.sh: 10: /usr/share/triggercmdagent/ app/src/daemonmgr.sh: cannot create /root/.TRIGGERcmdData/triggercmdagent.servic e: Directory nonexistent
          /usr/share/triggercmdagent/app/src/daemonmgr.sh: 11: /usr/share/triggercmdagent/ app/src/daemonmgr.sh: cannot create /root/.TRIGGERcmdData/triggercmdagent.servic e: Directory nonexistent
          cp: cannot stat '/root/.TRIGGERcmdData/triggercmdagent.service': No such file or directory
          Failed to start triggercmdagent.service: Unit triggercmdagent.service not found.
          Failed to enable unit: Unit file triggercmdagent.service does not exist.
          Unit triggercmdagent.service could not be found.
          pi@raspberrypi:~ $
            Russ @Antonio36996
            @Antonio36996, something went wrong with the installation. This could be tricky to fix. I noticed this command didn't even give you any output. Not even an error:
            I also noticed you're doing all of this as the pi user. The instructions have you switch to the root user with sudo su -
            I recommend trying those steps again as root, and add this command after the apt remove command:
            rm -rf /usr/share/triggercmdagent
            If that doesn't work, I recommend starting over with a fresh Raspbian installation. The new method using setup.bat is the easiest, but it assumes you're using a Windows computer. It also installs the agent for you.
            • A
              Antonio36996
              @Russ Thanks for answering, I can't reinstall raspbian again because I have other services like pihole, pivpn...
              At the beginning I could execute triggercmdagent and asked me to enter the token, however as the apt upgrade still being saying that wasn't successful I reinstalled it, and since that didn't work.
              This is my output using su
              pi@raspberrypi:~ $ sudo su -
              root@raspberrypi:~# apt remove triggercmdagent
              triggercmdagent
              root@raspberrypi:~# rm -rf /usr/share/triggercmdagent
              root@raspberrypi:~# dpkg -i triggercmdagent_1.0.1_all.deb
              triggercmdagent
              root@raspberrypi:~# triggercmdagent
              root@raspberrypi:~# /usr/share/triggercmdagent/app/src/installdaemon.sh
              root@raspberrypi:~# apt-get -y install npm nodejs
              nodejs is already the newest version (10.19.0~dfsg1-1).
              npm is already the newest version (5.8.0+ds6-4).
              triggercmdagent
              root@raspberrypi:~#
                Russ @Antonio36996
                @Antonio36996, I'm sorry about this trouble. Unfortunately the output isn't giving my much info to go on. Here's another idea you could try:
                sudo su -
                rm -rf /usr/share/triggercmdagent/app
                mkdir /usr/share/triggercmdagent/app
                • A
                  Antonio36996 @Russ
                  @Russ Does not work, thank you anyways!
                  • A
                    Antonio36996
                    Finnaly I solved it!!! As I was getting errors since I started, I decided to install node, which broke my nodejs installation, I found the answer here.
                    I removed the package node and everything went perfect! Thank you so much!
                      Russ @Antonio36996
                      @Antonio36996, nice job! I'm glad you got it working.
                      • Radosław SzałkowskiR
                        Radosław Szałkowski
                        @Russ I have a problem and I don't know what I'm doing wrong - I always have your default configuration file. I even tried to remove and install.
                        root@raspberrypi:/home/pi# triggercmdagent
                        Daemon install: false
                        Logging in with saved token.
                        Checking if the 5fb03d4f355bc6001903ba40 computer exists.
                        This computer was deleted from your account.  Login to recreate it.
                        prompt: token:  mytoken
                        Token saved for next time.
                        Computer ID 5fb0406efe27220019319bad saved for next time.
                        Write backup completed.
                                (using sails.io.js node SDK @v1.1.13)
                                 Connected at: Sat Nov 14 2020 20:39:12 GMT+0000 (Greenwich Mean Time)
                        Initiated command removals
                        Initiated command adds
                        { message: 'Subscribed to 5fb0406efe27220019319bad!' }
                        Added Gnome Editor
                        ^C
                        root@raspberrypi:/home/pi# nano /root/.TRIGGERcmdData/commands.json
                        root@raspberrypi:/home/pi# /usr/share/triggercmdagent/app/src/installdaemon.sh
                        Daemon install: true
                        Checking if the 5fb0406efe27220019319bad computer exists.
                           Active: active (running) since Sat 2020-11-14 20:42:06 GMT; 1s ago
                         Main PID: 11693 (node)
                            Tasks: 6 (limit: 2063)
                                   └─11693 node /usr/share/triggercmdagent/app/src/daemon.js --run /root/.TRIGGERcmdData
                        Nov 14 20:42:06 raspberrypi systemd[1]: Started TRIGGERcmd Agent.```
                        Maybe you have any idea? Thanks!
                          Russ @Radosław Szałkowski
                          @Radosław-Szałkowski, from that output it looks like the background service installation worked.
                          Can you show me the output of this command?
