    Now you can stop getting emails if your agent doesn't report "Command ran"
    Announcements
      When your commands run, the agent is supposed to log a "Command ran" entry in your command's Runs list. If that doesn't happen (usually because the agent is disconnected), you get an email that says:
      Hi (you),
      You tried to run a command on (your computer), but your TRIGGERcmd agent doesn't seem to be connected.
      The agent should have responded with a "Command ran" entry in the Runs list for (your command), but it didn't.
      Please restart the agent and try again.
      If you want to turn those emails off, check this new checkbox in your profile page:
      EDIT: I changed this to an opt-in checkbox instead of emailing by default:
