    Print a document
    • E
      edbgsk
      Hello,
      I am not sure whether it is possible or not to use triggercmd to print a document remotely using Alexa.
        Russ @edbgsk
        @edbgsk, I can send an example of how to do it. What sort of document would you print? A pdf?
        • E
          edbgsk
          Hi @Russ ,
          Yes, it is a PDF document.
          Appreciate your help.
          Thanks!
            Russ @edbgsk
            @edbgsk, a command like this should work. I shared my printer with a share name of "xerox".
            print /d:"\\mycomputer\xerox" c:\docs\test.pdf
