    voice commands or cli doesn't works anymore
    5 Posts 2 Posters 977 Views 1 Watching
    • A Offline
      alain
      my commands doesn't works , neither with website or on command line
      i try this
      triggercmdagent -t firefox -c kali
      regards
        Russ @alain
        @alain, for remotely executing your commands using a command, I recommend switching to the tcmd Go utility. That said, you need to get it working from the website first.
        Can you confirm the agent is still running?
        If it is running, you might learn something from the debug.log file in the ~/.TRIGGERcmdData directory.
        • A Offline
          alain
          thanks for replies Russ
          yes i think my triggercmdagent is working well
          here is my command
          Daemon install: false
          Logging in with saved token.
          Checking if the 5e4e6687b2275d00193c6347 computer exists.
          Write backup completed.
          Initiated command adds
          Initiated command removals
          (using sails.io.js node SDK @v1.1.13)
          Connected at: Thu Feb 20 2020 16:50:24 GMT+0100 (heure normale d’Europe centrale)
          { message: 'Subscribed to 5e4e6687b2275d00193c6347!' }
          and my Json
          {"trigger":"Editor","command":"nano","ground":"foreground","voice":"edition","allowParams": "false"},
          {"trigger":"Firefox","command":"/usr/bin/firefox","ground":"background","voice":"firefox","allowParams": "false"},
          {"trigger":"apt update","command":"apt-get -y update","ground":"background","voice":"update","allowParams": "false"}
          regards
            Russ @alain
            @alain, I see you're trying to use this method.
            I meant to replace that method with this one because it's faster, more reliable, and more consistent across platforms.
            I just put a note on that old article to refer people to the tcmd Go utility article.
            Would you mind trying that?
            I think you'll want to download the Linux 64bit version. Copy it to /usr/local/bin so it's in your PATH, rename it to tcmd, and make it executable with chmod +x /usr/local/bin/tcmd. Then your command will be:
            tcmd -t firefox -c kali
            • A Offline
              alain
              thanks Russ,
              i'll try this method
              regards
              With your input, this post could be even better đź’—
