    reverse Trigger Cmd
    5 Posts 3 Posters 1.1k Views 1 Watching
    • F Offline
      F4u5t
      I have finally found trigger cmd and love it, now I want to got the other way, have actions on my computer ( file write, application open...) cause a trigger on IFTTT or Alexa...
      anyone know how
      • F Offline
        F4u5t
        I think i can basically accomplish what I want with sendresult.bat
          Russ @F4u5t
          @F4u5t, the sendresult.bat script is meant for sending a small bit of data that your command produces back to the server. I don't think that matches your original post's use case.
          Here's a Powershell script you could use to watch for new processes, and call an API when one of the processes you're looking for launches. I had it call the TRIGGERcmd API, but you could easily switch it to the IFTTT Webhooks API.
          Let me know if you want a file write example too.
          # Define event Query
          # $query = "SELECT * FROM __InstanceCreationEvent WHERE TargetInstance ISA 'Win32_NTLogEvent' "
          $query = "SELECT * FROM Win32_ProcessStartTrace"
          <# Register for event - also specify an action that displays the event when the event fires.#>
          Register-WmiEvent -Source Demo1 -Query $query -Action {
                  $processes = "mspaint.exe","calculator.exe"
                  # Use this if reading Win32_NTLogEvent's:
                  #  $event.SourceEventArgs.NewEvent.TargetInstance.Message
                  $p = $event.SourceEventArgs.NewEvent.Properties["ProcessName"].value
                  foreach ($process in $processes) {
                      if ($p -eq $process) {
                          Write-Host "$p launched.  Calling API."
                          $postdata = @{
                              trigger='notepad'
                              computer='RussHP'
                              # params='optionalparameter.txt'
                          $token=Get-Content ~\.TRIGGERcmdData\token.tkn
                          $headers = New-Object "System.Collections.Generic.Dictionary[[String],[String]]"
                          $headers.Add("authorization", "Bearer " + $token)
                          $json = $postdata | ConvertTo-Json
                          $response = Invoke-RestMethod 'https://www.triggercmd.com/api/run/triggerSave' -Method Post -Body $json -ContentType 'application/json' -Headers $headers
                          write-host $response
          "Waiting for events.  Press CTRL-C to quit."
          while($true)
              Start-Sleep .5
          The script I based this one on watched for entries in Event Viewer. I left those bits remarked out in case you might have that use case.
          • F Offline
            F4u5t
            that is fantastic, Thank you! I've been learning much since stumbling on Triggercmd...I would love a example of a file write, and IFTTT would be sweet also.
            To be honest, ive never done much with Powershell, and its been years since i wrote batch files, I'm mainly c# nowadays
              Russ @F4u5t
              @F4u5t, here's an example to watch a folder for new files, and call the IFTTT webhook.
              $watcher = New-Object System.IO.FileSystemWatcher
              $watcher.Path = 'D:\folder_to_watch'
              $watcher.IncludeSubdirectories = $true
              $watcher.EnableRaisingEvents = $true
              $action =
                  $path = $event.SourceEventArgs.FullPath
                  $changetype = $event.SourceEventArgs.ChangeType
                  Write-Host "$path was $changetype at $(get-date)"
                  $postdata = @{
                      value1=$path
                      value2=$changetype
                  # To get your key, click the Documentation link at https://ifttt.com/maker_webhooks/
                  $key="your_ifttt_key"
                  $event="new_file"
                  $response = Invoke-RestMethod "https://maker.ifttt.com/trigger/$event/with/key/$key" -Method Post -Body $json -ContentType 'application/json'
              Register-ObjectEvent $watcher 'Created' -Action $action
              while($true)
                  Start-Sleep .5
