Issues with running on Retropie
I have run through all the steps to get triggercmd on my Raspberry Pi 3 b+ with the intention of starting it at bootup and have it running in the background to use Alexa voice commands to shutdown, but when I run triggercmdagent in terminal, it shows "Daemon install: false" and when using the command /usr/share/triggercmdagent/app/src/installdaemon.sh it says "Daemon install: true"
Despite my retropie showing up in computer management list, it only has one trigger: Gnome Editor. If I use nano ~/.TRIGGERcmdData/commands.json it shows 5 different triggers.
Alexa is not doing anything when I use the command "Alexa shutdown retropie"
Any help would be greatly appreciated. I'm not too savvy on Linux, so I'm relying on a lot of "how-to" posts.
Here are some things you can try and check.
First, the fact that your Raspberry Pi shows up in your TRIGGERcmd account on the website means you successfully logged it in with your token, but I'm not sure whether you were logged in as the pi user or the root user. This command is necessary to switch you do the root user:
sudo su -Also, Gnome Editor is a foreground command ( it has "ground": "foreground" in commands.json ). The fact that you only see that command means you only ran the agent in foreground mode so far.
What you want to do is get the agent running as root in background mode so it starts up as a daemon when your Raspberry Pi boots up.
If triggercmdagent running is running as root in background mode, the commands in /root/.TRIGGERcmdData/commands.json with "ground":"background" will show up on the website.
Please try these commands:
sudo su - /usr/share/triggercmdagent/app/src/removedaemon.sh /usr/share/triggercmdagent/app/src/installdaemon.shYou want to run removedaemon.sh before re-installing it just in case you've installed it wrong somehow.
Also, please run these commands. You should see output like below if it's working.
root@garagepi:~# ps -ef | grep triggercmd root 7610 1 0 Feb24 ? 00:41:49 node /usr/share/triggercmdagent/app/src/daemon.js --run /root/.TRIGGERcmdDataroot@garagepi:~# systemctl status triggercmdagent ā triggercmdagent.service - TRIGGERcmd Agent Loaded: loaded (/etc/systemd/system/triggercmdagent.service; enabled; vendor preset: enabled) Active: active (running) since Tue 2019-07-16 23:08:43 UTC; 1min 27s ago Main PID: 20448 (node) CGroup: /system.slice/triggercmdagent.service āā20448 node /usr/share/triggercmdagent/app/src/daemon.js --run /root/.TRIGGERcmdData Jul 16 23:08:46 garagepi env[20448]: Logging in with saved token to run background tasks. Jul 16 23:08:47 garagepi env[20448]: Write backup completed. -
@russ My outputs are slightly different (nothing mentioned about running in background) but an uninstall/reinstall of the daemon seems to have been enough to do the trick. I am now able to trigger commands remotely and everything I added to commands.json are showing on the website. Thanks so much!!
Boom! Awesome @bluefunoodle311 !
With your input, this post could be even better š
