    Can't enter token
    • D
      dennism
      Whenever I enter my token in the tokenfield, it gives me a JS-ENOENT error as seen here. After that, everytime I open the program the same error appears. Re-installing doesn't remove it, but removing the .TRIGGERcmdData folder in my user folder does fix it.
      EDIT: Didn't really make it clear in the post, but my issue was solved when I deleted the .TIGGERcmdData folder and restarted the agent. Just a bug report
      D RussR 2 Replies Last reply Reply Quote 0
      • D
        dennism @dennism
          Russ @dennism
          @dennism, thank you for reporting it. I confirmed this was a bug with version 20 of the Windows client. I pulled it off the site so the the link goes to version 19 again.
          I thought at first that this was just an Avast issue because I get this issue even with version 19 if I've got Avast installed. The workaround for Avast users is to temporarily disable it during the TRIGGERcmd agent install.
          EDIT: I created a new version (v21) that fixed the bug and includes v20's new feature for sending a command's result to the Runs list.
          Sorry for the bug, and thanks again for reporting it.
