[Linux] Failed to start triggercmdagent.service
I can't get the background service to start. I installed it via the TriggerCMD tray icon, but I received no visual feedback other than the authentication prompt to run
/bin/sh
as su.~ $ triggercmdagent Checking if the 598e58a42b4dea3166b86408 computer exists. This computer exists in your account. Tokenfile: /home/yochanan/.TRIGGERcmdData/token.tkn ComputerIDfile: /home/yochanan/.TRIGGERcmdData/computerid.cfg Logging in with saved token to run foreground tasks. ~ $ systemctl status triggercmdagent ā triggercmdagent.service Loaded: not-found (Reason: No such file or directory) Active: inactive (dead) ~ $ systemctl start triggercmdagent Failed to start triggercmdagent.service: Unit triggercmdagent.service not found.
I'm using TriggerCMD 1.0.1 on Linux Mint 18.2.
Off topic, but I'm not able to login to the TriggerCMD Android app via Google+. I get a 403 page with Error: disallowed_useragent. Google no longer allows OAuth requests to be made via webview. Also, it seems like it's just a web wrapper anyway, I may as well just use the mobile site.
@Yochanan , you're correct about the Android app - for now it's just a web wrapper with a cache. I'll work on updating the app to remove the Google login option for now. I recommend you go to https://www.triggercmd.com/user/computer/list and select "Add to Home screen". That's what I did. That way if you're already logged in, it goes right to your computer list.
About your background service - I'll install Linux Mint on a VM to troubleshoot why that option in the tray icon isn't working. I've only tested on CentOS and Ubuntu so far.
In the meantime, would you mind trying this?
sudo /usr/share/triggercmdagent/app/src/installdaemon.sh
EDIT: Correction, on Mint this is the path, and I noticed the file is not executable, so run:
sudo sh /usr/share/triggercmdagent/resources/app/src/installdaemon.sh
You don't want to switch to root first because you installed as your non-root user so you want it to look for your ~/.TRIGGERcmdData directory in your home directory.
@Yochanan , I installed Linux Mint 18.2 with KDE as my window manager, and I was able to install the service via the tray icon. What window manager are you using?
Be sure to to autostart the service boot -
sudo systemctl enable triggercmdagent.service
