    2. Murilo Callegari
    M Offline
    Murilo Callegari
    @Murilo Callegari
    Murilo Callegari Unfollow Follow
    • RE: Shutdown não funciona no mac
      @Waldex-Santos Todos os comandos eu uso pela Alexa, e no Mac Ventura eu uso o comando:
      Desligar o MacOS: osascript -e 'tell app "System Events" to shut down
      Trancar a tela com senha: osascript -e 'tell application "System Events" to keystroke "q" using {control down, command down}'
      Encerrar todos os aplicativos no modo "quit force": osascript -e 'tell app "System Events" to shut down' (Muito útil para quando o sistema congela!)
      Eu fiz automação com o sensor Tuya ou Zigbee da porta, toda vez que eu abro a porta do quarto o computador tranca, e quando eu saio de casa ele desliga sozinho!
      Assim fico seguro contra os enxeridos, porque utilizo muito o Amphetamine e na pressa saio as vezes sem lembrar de bloquear a tela ou antes do protetor de tela ter tempo hábil para isso.
      Essas automações de camadas de segurança todas são geridas pela Alexa e sensores de presença da Phillips Hue e também pelo sensor de contato da portas/janelas que é baratinho no Aliexpress que é Tuya...
      posted in Mac
      M
      Murilo Callegari
    • How can I get feedback that the command was executed remotely?
      I leave in a hurry, and forget the Mac is turned on and unlocked with Amphetamine active. I have doubts when away from the computer, I ask for Alexa on the iPhone. But would you like to know how to get feedback that the computer was actually locked/turned off?
      Even though I request the command, I don't have reliable feedback that it was executed successfully. Is there any other app that I can use together to find out if my Mac is active or an app that tells me if someone has turned on my computer every time it is turned on?
      I want to monitor my computer when I'm away, I'm worried if someone tries to use the computer to read my stuff.
      posted in Mac
      M
      Murilo Callegari
