    2. Mike Vecchiarelli
    Mike VecchiarelliM Offline
    • RE: 2 out of 4 computers have stopped running Commands
      @Russ See below for a visual reference...
      Trigger was sent. No command had ran. (referencing 5th row down - Mar 13 2024 13:18:05)
      Restarting it was not required in this case - it continued to run for other cases afterward.
      This is for a client of mine and I will try to retrieve the log asap.
      Mike VecchiarelliM
      Mike Vecchiarelli
      @Russ It's been a bit where the issue didn't happen, but it seems to have occurred again. In this instance, the following happened...
      I have an automation that will run from Zapier, part of it being a call to TriggerCMD. I checked the Zapier logs and see that I got a 200 response. I checked in the TriggerCMD logs and see that the Trigger was sent, but it was not Run. Let me know if there is some information I can provide that would be supportive of getting an answer to the issue that's occurring.
      Seems like from time to time the commands are received but don't run.
      For context, this entire thread would have the same context - running something from Zapier to TriggerCMD (as part of a longer list of activities).
      Anything you can do to support in quick order would be greatly appreciated! Thanks!
      Mike
      Mike VecchiarelliM
      Mike Vecchiarelli
      @Russ All foreground. It looks as if the computer had 3 TriggerCMD programs running (in the Task Manager) and that it had gone offline.
      What would cause this and how can I prevent it?
      Mike VecchiarelliM
      Mike Vecchiarelli
    • 2 out of 4 computers have stopped running Commands
      I have 4 computers. They all have like commands. I run commands via API calls through Zapier and Pipedream.
      All computers are receiving triggers (validated through the logs). But, as of yesterday, 2 of the computers have stopped running the commands that are sent...despite receiving the triggers from their source.
      Why would this happen? What would you need to see to support me with this. Getting this up and running again is quite important for me.
      Thank you!
      Mike VecchiarelliM
      Mike Vecchiarelli
