    2. Mevlüt Bora
    Mevlüt BoraM Offline
    • RE: shutdown pc not working Plsss
      @tuicemen I tried a few fixes but no success. Thank you for your support. I will try formatting.
      Mevlüt BoraM
      Mevlüt Bora
      @tuicemen Thanks for the help but it didn't work 😞
      Mevlüt BoraM
      Mevlüt Bora
      @Russ Screenshot_1.png Thank you for your quick reply. But unfortunately that didn't work either
      Mevlüt BoraM
      Mevlüt Bora
    • shutdown pc not working Plsss
      Hi, I've been using trigger cmd for over 2 years and it's only for a single function. shutdown PC. And in the mornings, I open the pc with google assistant without trigger cmd, but for a few days, I noticed that the computer did not turn off, the time it was open was more than 4 days. The important thing for me is trigger cmd, I only use the closing feature, not the opening feature. but as I said, it has not shut down for 4 days and I tried many things, but the pc does not turn off at all. Even try to turn it off manually with the GUI, it still didn't turn it off. trigger cmd deleted all data but still works in the same state If there is no solution, I will format the computer and try. I tried every article but it still didn't work Thanks in advance.
      Mevlüt BoraM
      Mevlüt Bora
