    2. Maximiliano Farinaro
    Maximiliano FarinaroM Offline
    • trouble with installation
      Hi, attached log. i cant, install .exe in windows. Thanks
      2020-07-25 20:01:07> Program: Starting Squirrel Updater: --install .
      2020-07-25 20:01:07> Program: Starting install, writing to C:\Users\Maxi\AppData\Local\SquirrelTemp
      2020-07-25 20:01:08> Program: About to install to: C:\Users\Maxi\AppData\Local\TRIGGERcmdAgent
      2020-07-25 20:01:09> CheckForUpdateImpl: Couldn't write out staging user ID, this user probably shouldn't get beta anything: System.IO.DirectoryNotFoundException: No se puede encontrar una parte de
      la ruta de acceso 'C:\Users\Maxi\AppData\Local\TRIGGERcmdAgent\packages.betaId'.
      en System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
      en System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs,
      String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)
      en System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options, String msgPath, Boolean bFromProxy, Boolean useLongPath,
      Boolean checkHost)
      en System.IO.StreamWriter.CreateFile(String path, Boolean append, Boolean checkHost)
      en System.IO.StreamWriter..ctor(String path, Boolean append, Encoding encoding, Int32 bufferSize, Boolean checkHost)
      en System.IO.File.InternalWriteAllText(String path, String contents, Encoding encoding, Boolean checkHost)
      en System.IO.File.WriteAllText(String path, String contents, Encoding encoding)
      en Squirrel.UpdateManager.CheckForUpdateImpl.getOrCreateStagedUserId()
      2020-07-25 20:01:09> CheckForUpdateImpl: Failed to load local releases, starting from scratch: System.IO.DirectoryNotFoundException: No se puede encontrar una parte de la ruta de acceso 'C:\Users
