@Smart-NET I personally haven't done this with mine, but what I'd recommend you do is upload a copy of the config file to a git repository. You could pull it down automatically, then
Posts made by Mark Hughes
RE: Configuration Transferposted in General Discussion
Using aliasesposted in General Discussion
Is there a way to create aliases that can be used by the daemon? So I've got a service running on my pi and the commands I created an alias for, but obviously they only work for my root user, not the daemon. Is there a way to define the same alias for the daemon, so that I can type that into the commands.json file instead of the full command?
