    2. Luis Gustavo
    Luis GustavoL Offline
    Luis Gustavo
    @Luis Gustavo
    Luis Gustavo Unfollow Follow
    • RE: Corsair RGB Keyboard and Mousepad turn lights off when Samsung monitor is turned off
      You should try this one instead:
      (Add-Type '[DllImport("user32.dll")]public static extern int SendMessage(int hWnd, int hMsg, int wParam, int lParam);' -Name a -Pas)::SendMessage(-1,0x0112,0xF170,2)
      Or, you can use a Powershell script like this:
      Add-Type -TypeDefinition '
      using System;
      using System.Runtime.InteropServices;
      namespace Utilities {
         public static class Display
            [DllImport("user32.dll", CharSet = CharSet.Auto)]
            private static extern IntPtr SendMessage(
               IntPtr hWnd,
               UInt32 Msg,
               IntPtr wParam,
               IntPtr lParam
            public static void PowerOff ()
               SendMessage(
                  (IntPtr)0xffff, // HWND_BROADCAST
                  0x0112,         // WM_SYSCOMMAND
                  (IntPtr)0xf170, // SC_MONITORPOWER
                  (IntPtr)0x0002  // POWER_OFF
      [Utilities.Display]::PowerOff()
      Luis GustavoL
      Luis Gustavo
    • RE: Best price for other countries
      Actually i'ts terrible expansive, as a comparison the minimum wage in USA is 7.25 USD (02-2021), while in Brazil is 1.2 USD (02-2021), ~604.16% more. So thinking about it, a fair price would be around 3.3 USD, equivalent of ~16.55% the original value.
      Luis GustavoL
      Luis Gustavo
    • RE: It works just perfect, but Brazilian Portuguese sentences are weird
      The correct structure would be:
      Alexa, execute notepad com o parâmetro X.
      Luis GustavoL
      Luis Gustavo
